  3. How can I find distance between components within a space?
2 Posts 2 Posters 663 Views
  • Mats_KnutssonM Offline
    Mats_Knutsson
    I’m trying to create a rule checking minimal distance from radiators and since Solibri doesn’t know which side of the radiator that is the front I need to restrict the checking to components within the same room aka space but I don’t know which rule that would do it!?
    Br,
    Mats
    S 1 Reply Last reply
      simon.gilbert Solibrians
      replied to Mats_Knutsson on last edited by
      @Mats_Knutsson said in How can I find distance between components within a space?:
      Hi Mats,
      Hopefully you can use Rule #222 Component distance to check the distance between components if you are checking for exclusion (minimum setting) or within a distance (maximum setting) to check if component conform to the distance requirements.
      Please see the example below where every WC requires a WHB to be within 750mm (don’t forget when using maximum distances you need to take into account the minimum number and this is initially set to 2).
      If you change the Space or Space Group Containment to Space from the default value Ignore Space or Space Group then you can ensure that it only checks distances to the target components based on the Source Component.
      • john.lippJ john.lipp referenced this topic on
