  3. BCF Live Connector not connecting
13 Posts 6 Posters 3.3k Views
  • Harmen JorritsmaH Offline
    replied to build effects on last edited by
    @build-effects
    Use https: not http.
    Try to set Googel Chrome for standard browser, restart te computer and try again.
    To verify on BIM Collab there has to open a internet pages, where verify that you are youy in BIm collab.
    Also look at te firewall if Solibri has rights.
      build effects
      Thank you for your quick answer šŸ™‚
      Chrome is already my standard browser and I already have the https…Also, when I click on the ā€œverifyā€ the bimcollab-page opens and I can log in, but in the end I still canĀ“t connect on solibri
        build effects
        Harmen JorritsmaH 1 Reply Last reply
          @build-effects
          Oke, sorry i can’t help u.
          This is strange.
          Maybe a fress instal of Solibri helps?
            replied to Harmen Jorritsma on last edited by
            I contacted BIMcollab because we have the same problem. Their response was this;
            This problem occurs with Solibri version 9.12.
            Please update to Solibri version 9.13 to resolve the problem.
            We just created an article to inform users via our helpcenter and we will keep this updated in case we have new information.
            https://helpcenter.bimcollab.com/portal/en/kb/articles/projects-not-available-in-solibri-bcf-live-connector-9-12
            Projects not available in Solibri BCF live connector (9.12)
            The solution looks simple, but it’s not. We can’t use 9.13 because it freezes a lot with bigger models.
            So I feel quite ā€˜stuck’ at the moment…
              @Ricardo How does 9.13 freeze. Could you share a model or create a video to show what happens?
              • hkringsKUBUSH Offline
                hkringsKUBUS
                @Pasi-Paasiala could it be that the fix for the Dalux authentication problem (https://society.solibri.com/topic/2204/sync-status-bimcollab/12) is related to the project selection problem?
                I noticed this fix was done around the time that the problems with BIMcollab started.
                  @Pasi We have this also. Happens to me a lot when dragging section planes.
                  My colleagues say that this helps… https://society.solibri.com/topic/2179/my-3d-view-freeze?_=1676885107123
                    replied to hkringsKUBUS on last edited by
                    @hkringsKUBUS The project selection problem is fixed already in 9.13 and the fix to Dalux authentication is fixed in the next release, so they’re different fixes.
                      @hkringsKUBUS This could be worked around on Bimcollab side also by adding the foundation API versions endpoint. The content of the endpoint should be the same as the one with BCF-API versions endpoint.
                      For example, the BCF-API end point for us is: https://solibri.bimcollab.com/bcf/versions
                      And the corresponding Foundation API end point would be: https://solibri.bimcollab.com/foundation/versions
                      hkringsKUBUSH 1 Reply Last reply
                        hkringsKUBUS
                        @Pasi-Paasiala said in BCF Live Connector not connecting:
                        Thank you Pasi, I’ve forwarded this to the BIMcollab developers.
                          @build-effects @JeroenKoomen @Harmen-Jorritsma @Ricardo @hkringsKUBUS
                          It seems that this is now working. Apparently Bimcollab is throwing and exception that version 9.12 can handle. Yesterday it threw an exception that 9.12 cannot handle, but 9.13 can.
                          Copyright Ā© 2025 Solibri Inc. | Powered by NodeBB
