  4. Check distance opening with the component in front of it.
rules
3 Posts 2 Posters 1.1k Views
  • Robbert EversR Offline
    Robbert Evers
    wrote on last edited by Eric
    Hi guys,
    I’m trying to check if an opening is bigger then it supposed to be, how to get a result by checking on it.
    I used many rules like: component distance SOL/222/4.1, Components must touch each other SOL23/5.1, a component inside component Sol234/1.2.
    But still can’t find the right rule to check on it.
    This check would be great to check if the opening that the is delivered by the supplier, could be checked if the distance/opening is too big compared to the opening that the contractor in first place suggested.
    I have added the files https://we.tl/t-pPfCDXaSxR
    If i’m not clear enough or it isn’t possible i like to hear from you,
    [2_1549877205711_Project1.smc](Uploading 100%) [1_1549877205710_Project1.rvt](Uploading 100%) [0_1549877205709_Project1.ifc](Uploading 100%)
    • HannesH Offline
      HannesH Offline
      Hannes
      Hey Robbert,
      try rule rule SOL/226 with a little adjustments. See the file. Idea is, that an opening should hav space in both directions. Doors and Openings are allowed. Maybe this helps.
      http://share.a-null.com/Project1-10655.zip
      Hannes
        Robbert Evers
        Hi Hannes,
        Thanks for the reply. I tried it and it helps me a bit, so I’m satisfied haha.
