  4. Finging Provisions for Voids that are object free
6 Posts 3 Posters 862 Views
    Seba
    I am trying to find in a model Provisions for Voids that don’t contain any HVAC or electrical, in such a way that the results would only show the Provisions for Voids that are empty of HVAC or electrical. I have tried a few rules without success, I am most likely missing some crucial part of a rule, and at the moment I can not think of a way complete the task with the rules.
    Any help would be appreciated.
    Many thanks
    Regards,
    Sebastian
      replied to Seba on last edited by
      @sebastian-nybäck
      SOL234 for example should cover your described use case. Use the component filter and then you can specify the ‘Minimum Amount’ of the inner components there. If the number of inner components inside another component is less than e.g. 1 then an issue should be created.
        Seba
        Thank you for you answer! It sure helped!
        L 1 Reply Last reply
          LindaFernstrom
          @sebastian-nybäck I would also like to know but I can´t find SOL234. Could you link to that issue please?
            Seba
            @LindaFernstrom The rule can be found from the Ruleset manager in the "Solibri Common Rules folder.
              LindaFernstrom
              @sebastian-nybäck Ah thank you!
