  4. Check angles on roofs?
Scheduled Pinned Locked Moved Unsolved Tech Talks
8 Posts 7 Posters 2.2k Views
  • JoelJ Offline
    JoelJ Offline
    Joel
    Hello!
    Is there or will there be an implementation of degree checking of roofs and other angles planned for Solibri? It’s a feature being asked for at the office.
    Thank you!
    /Best regards
    Joel Öman
    RobinKramerR 1 Reply Last reply
    9
    • RobinKramerR Offline
      RobinKramer
      replied to Joel on last edited by RobinKramer
      @Joel I would refer to this post for the angles on roofs. This feature is requested a lot during Solibri trainings (Office and Anywhere) by using the dimension tool.
      @Solibrians Could you help with this one?
        Mvandenbrink
        wrote on last edited by Mvandenbrink
        @Joel @RobinKramer During our Solibri trainings this is also one of the most frequently asked questions (Using the dimension tool to measure angles). @Solibrians Any news if this will be on your roadmap?
          It is useful, but the reason why there is no rule or even dimension to check this is because in the IFC Structure there is no Pset or whatsoever to have this parameter. Especially in IFC2x3 there is no parameter, whereby in IFC4 you can find an IfcPitchedAngle for an IfcSlab.
          I am happy to hear any suggestions how to create a rule to check this one…
          TriPoint GmbH
          www.tri-point.at
            @agroni said in Check angles on roofs?:
            Well, at least the possibility to dimension angles would be a nice first step. 😊
              simon.gilbert Solibrians
              Please check that you are not looking at a roof at the parent level. i.e. if the roof has multiple faces then the parent object will not contain the Pset_slabcommon.pitchAngle parameter. Selecting the parent roof component and then accessing its child decomposes relationship (relations tab) and then selecting one of the individual roof faces will then give you access to this data. Therefore your rules need to use the decomposite relationship only checking the child elements for the pitch angle. You can then use rule #230 Property rule template with component filters to do this. This should hopefully resolve your problem.
              M 1 Reply Last reply
                Mvandenbrink
                replied to simon.gilbert on last edited by
                @simon-gilbert said in Check angles on roofs?:
                Thanks for pointing this out. But this feature request isn’t only about roof angles. Participants of our trainings also would like to check angles between two connected walls or between a floor and a sloped wall. Measuring angles with the dimension tool(face or line based) would be a good start. SketchUp and BIMvision both have workable dimension tools to measure angles for example.
                • F Offline
                  F Offline
                  fsdalen
                  Angle and slope would be very useful to have as dimension/markup tools.
