  3. Solibri and Virtual Desktops
10 Posts 3 Posters 2.3k Views
  • pejotuP Offline
    pejotuP Offline
    pejotu
    I’ve recently gotten into the habit of useing virtual desktops on Windows 10. (for clarifications, this shouldn’t be seen as anything new or exotic, its just a way to gather application windows on separate ‘virtual’ desktop views - when i switch to another desktop view, I can quickly have a set of windows laid out on top, instead of toggling all of them on individually, or just compartmentalize taskas on different desktops - also, this is quite useful for remote meetings, so I can have a clutter free layout when screen sharing)
    But Solibri seems to have issues with this - if I have Solibri starting up on desktop 1 (not yet opening an SMC), and I switch to another desktop during this, Solibri may just disappear entirely (crash).
    Is this a knwon issue? Surely an application should be able to start up ‘left to it’s own’, and not need my eyes in the splash screen?? This also makes autorun tasks a pain to run.
      Hi. Are you able to provide logs from these crashes? They are usually located in C:\Program Files\Solibri\SOLIBRI\log
      pejotuP 2 Replies Last reply
        We have had a smiliar experience on a remote desktip connection. Not directly a crash of the application itself but strangely views are stopping to work - especially when we use a custom view it is necessary to restart Solibri every while again to make it work. I thought it might be due to issues with the view itself but it might be related to this. However unfortunately for that events we cannot provide any logs.
        • pejotuP Offline
          pejotuP Offline
          pejotu
          @lasse-lindqvist Sorry for the delay, I missed your reply last week while busy on other work.
          Here are copies from my logs - my process was:
          1. I cleared the logs runtime.log, error.log, gc.log and output.log
          2. On virtual desktop 2, I opened Solibri and a model at 11:52 . This time no issues, the model opened as normal.
          3. I switched to virtual desktop 1, and opened another instance of Solibri at 11:55 and started opening another model.
          4. After less than a minute, the second instance of Solibri disappeared (crashed) from virtual desktop 1.
          5. [while writing this, I think also the first instance of Solibri diasppeared from virtual desktop 2], unsure of timestamp.
          6. Starting again, on virtual desktop 1, at 13:00 I start a new instance of Solibri (no remaining instances open before this), opening the same model as at step 2.
          7. The model opens, finishes processing geometry, shows the model in the 3D window, and crashes instantly at 13:07 (this is a largish model).
          The resulting logs in full:
          Runtime.log
          12:52:17.138 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
          12:52:17.142 [main] INFO  com.solibri.saf.core.Application - Java version: 16
          12:52:17.142 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
          12:52:17.143 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
          12:52:17.221 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
          12:52:21.377 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 12.52.21 for 3480 seconds. License type = FLOATING
          12:52:21.381 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
          12:52:22.224 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
          12:52:22.762 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
          12:52:22.762 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
          12:52:22.762 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 496.49
          12:52:24.115 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
          12:52:25.652 [main] INFO  com.solibri.saf.core.Application - Starting application
          12:52:25.653 [main] INFO  com.solibri.saf.core.Application - Application started
          12:52:25.653 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
          12:55:04.804 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
          12:55:04.808 [main] INFO  com.solibri.saf.core.Application - Java version: 16
          12:55:04.808 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
          12:55:04.808 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
          12:55:04.879 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
          12:55:10.073 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 12.55.10 for 3480 seconds. License type = FLOATING
          12:55:10.075 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
          12:55:10.661 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
          12:55:11.359 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
          12:55:11.359 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
          12:55:11.359 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 496.49
          12:55:13.232 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
          12:55:14.827 [main] INFO  com.solibri.saf.core.Application - Starting application
          12:55:14.827 [main] INFO  com.solibri.saf.core.Application - Application started
          12:55:14.828 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
          13:00:39.599 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
          13:00:39.603 [main] INFO  com.solibri.saf.core.Application - Java version: 16
          13:00:39.603 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
          13:00:39.603 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
          13:00:39.667 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
          13:00:44.412 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 13.00.44 for 3479 seconds. License type = FLOATING
          13:00:44.414 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
          13:00:44.929 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
          13:00:45.469 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
          13:00:45.470 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
          13:00:45.470 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 496.49
          13:00:46.702 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
          13:00:48.377 [main] INFO  com.solibri.saf.core.Application - Starting application
          13:00:48.379 [main] INFO  com.solibri.saf.core.Application - Application started
          13:00:48.379 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
          output.log
          gc.log
          -XX:+PrintGC is deprecated. Will use -Xlog:gc instead.
          [0.053s][info][gc] Using G1
          [6.251s][info][gc] GC(0) Pause Young (Normal) (G1 Evacuation Pause) 48M->17M(1024M) 7.918ms
          [6.505s][info][gc] GC(1) Pause Young (Concurrent Start) (Metadata GC Threshold) 28M->19M(1024M) 5.788ms
          [6.505s][info][gc] GC(2) Concurrent Mark Cycle
          [6.514s][info][gc] GC(2) Pause Remark 20M->20M(224M) 1.105ms
          [6.520s][info][gc] GC(2) Pause Cleanup 20M->20M(224M) 0.035ms
          [6.521s][info][gc] GC(2) Concurrent Mark Cycle 15.673ms
          [7.586s][info][gc] GC(3) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 51M->25M(224M) 3.780ms
          [7.952s][info][gc] GC(4) Pause Young (Mixed) (G1 Evacuation Pause) 41M->26M(224M) 3.464ms
          [9.526s][info][gc] GC(5) Pause Young (Normal) (G1 Evacuation Pause) 90M->33M(224M) 10.088ms
          [9.539s][info][gc] GC(6) Pause Young (Concurrent Start) (Metadata GC Threshold) 35M->34M(224M) 8.204ms
          [9.539s][info][gc] GC(7) Concurrent Mark Cycle
          [9.564s][info][gc] GC(7) Pause Remark 36M->36M(224M) 1.990ms
          [9.570s][info][gc] GC(7) Pause Cleanup 36M->36M(224M) 0.033ms
          [9.572s][info][gc] GC(7) Concurrent Mark Cycle 32.685ms
          [12.354s][info][gc] GC(8) Pause Young (Concurrent Start) (G1 Evacuation Pause) 114M->40M(224M) 7.940ms
          [12.354s][info][gc] GC(9) Concurrent Mark Cycle
          [12.384s][info][gc] GC(9) Pause Remark 43M->43M(224M) 1.904ms
          [12.391s][info][gc] GC(9) Pause Cleanup 43M->43M(224M) 0.037ms
          [12.391s][info][gc] GC(9) Concurrent Mark Cycle 37.242ms
          [13.865s][info][gc] GC(10) Pause Young (Normal) (G1 Evacuation Pause) 136M->52M(224M) 10.592ms
          [15.677s][info][gc] GC(11) Pause Young (Normal) (G1 Evacuation Pause) 132M->67M(224M) 10.918ms
          [16.528s][info][gc] GC(12) Pause Young (Concurrent Start) (Metadata GC Threshold) 114M->79M(224M) 9.200ms
          [16.528s][info][gc] GC(13) Concurrent Mark Cycle
          [16.582s][info][gc] GC(13) Pause Remark 84M->84M(224M) 2.640ms
          [16.612s][info][gc] GC(13) Pause Cleanup 86M->86M(224M) 0.038ms
          [16.612s][info][gc] GC(13) Concurrent Mark Cycle 84.047ms
          [17.509s][info][gc] GC(14) Pause Young (Normal) (G1 Evacuation Pause) 127M->89M(224M) 8.210ms
          [20.348s][info][gc] GC(15) Pause Young (Normal) (G1 Evacuation Pause) 137M->96M(224M) 7.040ms
          [20.566s][info][gc] GC(16) Pause Young (Normal) (G1 Evacuation Pause) 144M->111M(224M) 9.317ms
          [20.654s][info][gc] GC(17) Pause Young (Concurrent Start) (G1 Evacuation Pause) 143M->121M(224M) 8.470ms
          [20.654s][info][gc] GC(18) Concurrent Mark Cycle
          [20.715s][info][gc] GC(19) Pause Young (Normal) (G1 Evacuation Pause) 137M->126M(224M) 5.191ms
          [20.731s][info][gc] GC(18) Pause Remark 135M->135M(272M) 3.797ms
          [20.762s][info][gc] GC(20) Pause Young (Normal) (G1 Evacuation Pause) 142M->135M(272M) 6.660ms
          [20.774s][info][gc] GC(18) Pause Cleanup 137M->137M(272M) 0.043ms
          [20.774s][info][gc] GC(18) Concurrent Mark Cycle 120.202ms
          [20.888s][info][gc] GC(21) Pause Young (Normal) (G1 Evacuation Pause) 183M->148M(272M) 10.664ms
          [20.952s][info][gc] GC(22) Pause Young (Concurrent Start) (G1 Evacuation Pause) 180M->158M(544M) 13.844ms
          [20.952s][info][gc] GC(23) Concurrent Mark Cycle
          [21.022s][info][gc] GC(23) Pause Remark 199M->199M(544M) 6.670ms
          [21.060s][info][gc] GC(23) Pause Cleanup 215M->215M(544M) 0.037ms
          [21.062s][info][gc] GC(23) Concurrent Mark Cycle 109.297ms
          [21.351s][info][gc] GC(24) Pause Young (Normal) (G1 Evacuation Pause) 318M->223M(544M) 28.882ms
          [21.602s][info][gc] GC(25) Pause Young (Normal) (G1 Evacuation Pause) 367M->278M(544M) 22.943ms
          [21.776s][info][gc] GC(26) Pause Young (Concurrent Start) (G1 Evacuation Pause) 374M->308M(544M) 23.371ms
          [21.777s][info][gc] GC(27) Concurrent Mark Cycle
          [21.904s][info][gc] GC(27) Pause Remark 380M->380M(672M) 5.541ms
          [21.935s][info][gc] GC(28) Pause Young (Normal) (G1 Evacuation Pause) 388M->332M(672M) 16.862ms
          [21.990s][info][gc] GC(27) Pause Cleanup 369M->369M(672M) 0.039ms
          [21.992s][info][gc] GC(27) Concurrent Mark Cycle 215.364ms
          [22.173s][info][gc] GC(29) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 444M->366M(672M) 18.125ms
          [22.245s][info][gc] GC(30) Pause Young (Mixed) (G1 Evacuation Pause) 382M->353M(1312M) 45.163ms
          [23.126s][info][gc] GC(31) Pause Young (Normal) (G1 Evacuation Pause) 849M->553M(1312M) 47.913ms
          [23.699s][info][gc] GC(32) Pause Young (Normal) (G1 Evacuation Pause) 841M->640M(1312M) 46.744ms
          [23.886s][info][gc] GC(33) Pause Young (Concurrent Start) (G1 Humongous Allocation) 751M->686M(1312M) 24.832ms
          [23.886s][info][gc] GC(34) Concurrent Mark Cycle
          [24.188s][info][gc] GC(34) Pause Remark 892M->860M(1472M) 6.538ms
          [24.407s][info][gc] GC(34) Pause Cleanup 942M->942M(1472M) 0.131ms
          [24.411s][info][gc] GC(34) Concurrent Mark Cycle 524.271ms
          [24.558s][info][gc] GC(35) Pause Young (Normal) (G1 Evacuation Pause) 990M->818M(1472M) 41.101ms
          [25.077s][info][gc] GC(36) Pause Young (Concurrent Start) (G1 Evacuation Pause) 1074M->896M(4224M) 91.263ms
          [25.078s][info][gc] GC(37) Concurrent Mark Cycle
          [25.402s][info][gc] GC(37) Pause Remark 1040M->976M(3264M) 4.170ms
          [25.625s][info][gc] GC(37) Pause Cleanup 1072M->1072M(3264M) 0.319ms
          [25.638s][info][gc] GC(37) Concurrent Mark Cycle 560.327ms
          [28.219s][info][gc] GC(38) Pause Young (Normal) (G1 Evacuation Pause) 2240M->1449M(3264M) 222.986ms
          [28.638s][info][gc] GC(39) Pause Young (Normal) (G1 Evacuation Pause) 1609M->1512M(3264M) 99.137ms
          [29.913s][info][gc] GC(40) Pause Young (Concurrent Start) (G1 Humongous Allocation) 2152M->1704M(3264M) 81.237ms
          [29.913s][info][gc] GC(41) Concurrent Mark Cycle
          [30.630s][info][gc] GC(41) Pause Remark 2048M->1936M(3264M) 3.180ms
          [31.317s][info][gc] GC(41) Pause Cleanup 2160M->2160M(3264M) 0.118ms
          [31.328s][info][gc] GC(41) Concurrent Mark Cycle 1414.745ms
          [31.666s][info][gc] GC(42) Pause Young (Normal) (G1 Evacuation Pause) 2264M->1786M(3264M) 90.699ms
          [31.872s][info][gc] GC(43) Pause Young (Concurrent Start) (G1 Humongous Allocation) 1842M->1826M(3264M) 99.868ms
          [31.872s][info][gc] GC(44) Concurrent Mark Cycle
          [32.857s][info][gc] GC(44) Pause Remark 2250M->2250M(3792M) 7.453ms
          [33.128s][info][gc] GC(45) Pause Young (Normal) (G1 Evacuation Pause) 2338M->1976M(3792M) 66.212ms
          [33.566s][info][gc] GC(44) Pause Cleanup 2176M->2176M(3792M) 0.098ms
          [33.571s][info][gc] GC(44) Concurrent Mark Cycle 1699.055ms
          [34.751s][info][gc] GC(46) Pause Young (Normal) (G1 Evacuation Pause) 2712M->2194M(3792M) 104.882ms
          [35.242s][info][gc] GC(47) Pause Young (Concurrent Start) (G1 Humongous Allocation) 2386M->2271M(8448M) 139.419ms
          [35.242s][info][gc] GC(48) Concurrent Undo Cycle
          [35.267s][info][gc] GC(48) Concurrent Undo Cycle 24.982ms
          [37.529s][info][gc] GC(49) Pause Young (Normal) (G1 Evacuation Pause) 3455M->2954M(8448M) 152.053ms
          [38.242s][info][gc] GC(50) Pause Young (Normal) (G1 Evacuation Pause) 3258M->3056M(8448M) 85.289ms
          [39.646s][info][gc] GC(51) Pause Young (Normal) (G1 Evacuation Pause) 3760M->3277M(8448M) 88.331ms
          [41.530s][info][gc] GC(52) Pause Young (Normal) (G1 Evacuation Pause) 4157M->3543M(13312M) 212.470ms
          [42.942s][info][gc] GC(53) Pause Young (Normal) (G1 Evacuation Pause) 4151M->3738M(13312M) 120.932ms
          [44.759s][info][gc] GC(54) Pause Young (Normal) (G1 Evacuation Pause) 4618M->4009M(13312M) 155.521ms
          [46.596s][info][gc] GC(55) Pause Young (Normal) (G1 Evacuation Pause) 4793M->4319M(13312M) 159.162ms
          [48.269s][info][gc] GC(56) Pause Young (Normal) (G1 Evacuation Pause) 5199M->4588M(14832M) 179.052ms
          [50.613s][info][gc] GC(57) Pause Young (Normal) (G1 Evacuation Pause) 6060M->5566M(14832M) 161.736ms
          [52.695s][info][gc] GC(58) Pause Young (Normal) (G1 Evacuation Pause) 6494M->5866M(14832M) 161.055ms
          [54.008s][info][gc] GC(59) Pause Young (Normal) (G1 Evacuation Pause) 6506M->6075M(14832M) 130.066ms
          [55.782s][info][gc] GC(60) Pause Young (Normal) (G1 Evacuation Pause) 7003M->6352M(14832M) 151.981ms
          [57.988s][info][gc] GC(61) Pause Young (Normal) (G1 Evacuation Pause) 7312M->6704M(15888M) 222.320ms
          [60.041s][info][gc] GC(62) Pause Young (Normal) (G1 Evacuation Pause) 7440M->6940M(15888M) 226.970ms
          [61.979s][info][gc] GC(63) Pause Young (Normal) (G1 Evacuation Pause) 7692M->7222M(15888M) 327.668ms
          [63.444s][info][gc] GC(64) Pause Young (Normal) (G1 Evacuation Pause) 7894M->7435M(15888M) 128.924ms
          [64.906s][info][gc] GC(65) Pause Young (Concurrent Start) (G1 Evacuation Pause) 8107M->7652M(17744M) 223.891ms
          [64.906s][info][gc] GC(66) Concurrent Mark Cycle
          [67.170s][info][gc] GC(67) Pause Young (Normal) (G1 Evacuation Pause) 8420M->7920M(17744M) 156.502ms
          [68.324s][info][gc] GC(66) Pause Remark 8432M->7808M(17744M) 2.976ms
          [69.087s][info][gc] GC(68) Pause Young (Normal) (G1 Evacuation Pause) 8064M->7536M(17744M) 152.968ms
          [71.285s][info][gc] GC(69) Pause Young (Normal) (GCLocker Initiated GC) 8304M->7904M(17744M) 158.558ms
          [71.706s][info][gc] GC(66) Pause Cleanup 8072M->8072M(17744M) 0.411ms
          [71.767s][info][gc] GC(66) Concurrent Mark Cycle 6860.887ms
          [73.221s][info][gc] GC(70) Pause Young (Normal) (G1 Evacuation Pause) 8672M->8255M(17744M) 121.287ms
          [75.035s][info][gc] GC(71) Pause Young (Concurrent Start) (G1 Evacuation Pause) 9023M->8631M(17744M) 133.284ms
          [75.035s][info][gc] GC(72) Concurrent Mark Cycle
          [77.221s][info][gc] GC(73) Pause Young (Normal) (GCLocker Initiated GC) 9399M->8992M(17744M) 223.076ms
          [79.085s][info][gc] GC(74) Pause Young (Normal) (G1 Evacuation Pause) 9760M->9296M(19968M) 183.445ms
          [79.474s][info][gc] GC(72) Pause Remark 9408M->9408M(19968M) 3.040ms
          [82.170s][info][gc] GC(75) Pause Young (Normal) (G1 Evacuation Pause) 10176M->9696M(19968M) 260.136ms
          [83.400s][info][gc] GC(72) Pause Cleanup 10840M->10840M(19968M) 0.498ms
          [83.455s][info][gc] GC(72) Concurrent Mark Cycle 8420.105ms
          [85.203s][info][gc] GC(76) Pause Young (Normal) (G1 Evacuation Pause) 12096M->11496M(19968M) 175.007ms
          [87.004s][info][gc] GC(77) Pause Young (Concurrent Start) (G1 Evacuation Pause) 12360M->11776M(19968M) 169.847ms
          [87.004s][info][gc] GC(78) Concurrent Mark Cycle
          [89.075s][info][gc] GC(79) Pause Young (Normal) (GCLocker Initiated GC) 12656M->12077M(19968M) 144.567ms
          [91.056s][info][gc] GC(80) Pause Young (Normal) (G1 Evacuation Pause) 13005M->12381M(19968M) 154.858ms
          [92.151s][info][gc] GC(78) Pause Remark 12729M->11993M(20000M) 3.146ms
          [93.695s][info][gc] GC(81) Pause Young (Normal) (G1 Evacuation Pause) 12589M->12038M(20000M) 177.297ms
          [96.094s][info][gc] GC(78) Pause Cleanup 12870M->12870M(20000M) 0.514ms
          [96.115s][info][gc] GC(78) Concurrent Mark Cycle 9110.245ms
          [96.347s][info][gc] GC(82) Pause Young (Normal) (GCLocker Initiated GC) 12902M->12519M(20000M) 149.637ms
          [98.716s][info][gc] GC(83) Pause Young (Concurrent Start) (G1 Evacuation Pause) 13383M->13128M(20000M) 213.798ms
          [98.716s][info][gc] GC(84) Concurrent Mark Cycle
          [101.023s][info][gc] GC(85) Pause Young (Normal) (G1 Evacuation Pause) 13992M->13648M(22976M) 200.630ms
          [104.224s][info][gc] GC(86) Pause Young (Normal) (GCLocker Initiated GC) 14656M->14248M(22976M) 182.880ms
          [104.547s][info][gc] GC(84) Pause Remark 14368M->14336M(23920M) 17.505ms
          [107.044s][info][gc] GC(87) Pause Young (Normal) (G1 Evacuation Pause) 15272M->14760M(23920M) 118.516ms
          [108.690s][info][gc] GC(84) Pause Cleanup 15648M->15648M(23920M) 0.629ms
          [108.723s][info][gc] GC(84) Concurrent Mark Cycle 10007.334ms
          [109.085s][info][gc] GC(88) Pause Young (Normal) (G1 Evacuation Pause) 15800M->15112M(23920M) 137.521ms
          [110.911s][info][gc] GC(89) Pause Young (Concurrent Start) (G1 Evacuation Pause) 16136M->15456M(23920M) 149.797ms
          [110.911s][info][gc] GC(90) Concurrent Mark Cycle
          [113.084s][info][gc] GC(91) Pause Young (Normal) (G1 Evacuation Pause) 16480M->15799M(23920M) 210.404ms
          [115.353s][info][gc] GC(92) Pause Young (Normal) (G1 Evacuation Pause) 16823M->16136M(25680M) 210.681ms
          [117.438s][info][gc] GC(90) Pause Remark 16968M->16968M(28320M) 46.884ms
          [118.311s][info][gc] GC(93) Pause Young (Normal) (G1 Evacuation Pause) 17256M->16495M(28320M) 214.199ms
          [121.322s][info][gc] GC(94) Pause Young (Normal) (G1 Evacuation Pause) 17743M->16912M(28320M) 210.370ms
          [122.464s][info][gc] GC(90) Pause Cleanup 17280M->17280M(28320M) 0.883ms
          [122.517s][info][gc] GC(90) Concurrent Mark Cycle 11605.673ms
          [122.741s][info][gc] GC(95) Pause Young (Concurrent Start) (G1 Humongous Allocation) 17312M->17232M(28320M) 160.060ms
          [122.741s][info][gc] GC(96) Concurrent Mark Cycle
          [127.303s][info][gc] GC(97) Pause Young (Normal) (G1 Evacuation Pause) 18640M->17920M(28320M) 241.564ms
          [130.156s][info][gc] GC(96) Pause Remark 18992M->18944M(31584M) 56.927ms
          [131.010s][info][gc] GC(98) Pause Young (Normal) (G1 Evacuation Pause) 19168M->18360M(31584M) 220.177ms
          [135.487s][info][gc] GC(99) Pause Young (Normal) (G1 Evacuation Pause) 19752M->18984M(31584M) 237.922ms
          [135.923s][info][gc] GC(96) Pause Cleanup 19168M->19168M(31584M) 0.879ms
          [135.974s][info][gc] GC(96) Concurrent Mark Cycle 13232.551ms
          [137.178s][info][gc] GC(100) Pause Young (Concurrent Start) (G1 Humongous Allocation) 19659M->19264M(31584M) 276.824ms
          [137.178s][info][gc] GC(101) Concurrent Mark Cycle
          [141.092s][info][gc] GC(102) Pause Young (Normal) (G1 Evacuation Pause) 20672M->19792M(32016M) 372.505ms
          [145.194s][info][gc] GC(103) Pause Young (Normal) (G1 Evacuation Pause) 21184M->20304M(32016M) 483.659ms
          [146.090s][info][gc] GC(101) Pause Remark 20648M->20552M(32720M) 13.297ms
          [149.208s][info][gc] GC(104) Pause Young (Normal) (G1 Evacuation Pause) 21600M->20720M(32720M) 379.472ms
          [152.746s][info][gc] GC(101) Pause Cleanup 24784M->24784M(32720M) 0.974ms
          [152.784s][info][gc] GC(101) Concurrent Mark Cycle 15605.158ms
          [154.868s][info][gc] GC(105) Pause Young (Concurrent Start) (G1 Humongous Allocation) 24880M->24048M(32720M) 413.032ms
          [154.868s][info][gc] GC(106) Concurrent Mark Cycle
          [158.625s][info][gc] GC(107) Pause Young (Normal) (G1 Evacuation Pause) 25504M->24720M(32720M) 764.420ms
          [170.039s][info][gc] GC(106) Pause Remark 25664M->24224M(32720M) 2.883ms
          [0.011s][info][gc] Using G1
          [1.322s][info][gc] GC(0) Pause Young (Normal) (G1 Evacuation Pause) 48M->17M(1024M) 7.529ms
          [1.579s][info][gc] GC(1) Pause Young (Concurrent Start) (Metadata GC Threshold) 28M->19M(1024M) 8.279ms
          [1.579s][info][gc] GC(2) Concurrent Mark Cycle
          [1.592s][info][gc] GC(2) Pause Remark 19M->19M(224M) 0.983ms
          [1.596s][info][gc] GC(2) Pause Cleanup 19M->19M(224M) 0.028ms
          [1.597s][info][gc] GC(2) Concurrent Mark Cycle 18.870ms
          [2.677s][info][gc] GC(3) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 51M->24M(224M) 4.310ms
          [2.976s][info][gc] GC(4) Pause Young (Mixed) (G1 Evacuation Pause) 40M->25M(224M) 3.803ms
          [5.122s][info][gc] GC(5) Pause Young (Concurrent Start) (G1 Evacuation Pause) 89M->33M(224M) 11.160ms
          [5.122s][info][gc] GC(6) Concurrent Mark Cycle
          [5.199s][info][gc] GC(6) Pause Remark 35M->35M(224M) 1.621ms
          [5.204s][info][gc] GC(6) Pause Cleanup 35M->35M(224M) 0.028ms
          [5.205s][info][gc] GC(6) Concurrent Mark Cycle 83.294ms
          [178.054s][info][gc] GC(108) Pause Young (Normal) (G1 Evacuation Pause) 24704M->23466M(32720M) 524.060ms
          [179.474s][info][gc] GC(106) Pause Cleanup 23658M->23658M(32720M) 1.519ms
          [179.502s][info][gc] GC(106) Concurrent Mark Cycle 24634.275ms
          [180.587s][info][gc] GC(109) Pause Young (Normal) (G1 Evacuation Pause) 24938M->23589M(32720M) 127.880ms
          [8.253s][info][gc] GC(7) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 113M->41M(224M) 10.690ms
          [8.490s][info][gc] GC(8) Pause Young (Mixed) (G1 Evacuation Pause) 57M->43M(224M) 6.447ms
          [181.838s][info][gc] GC(110) Pause Young (Concurrent Start) (G1 Evacuation Pause) 25109M->23660M(32720M) 79.427ms
          [181.838s][info][gc] GC(111) Concurrent Mark Cycle
          [9.195s][info][gc] GC(9) Pause Young (Concurrent Start) (Metadata GC Threshold) 79M->46M(224M) 3.091ms
          [9.195s][info][gc] GC(10) Concurrent Mark Cycle
          [9.262s][info][gc] GC(10) Pause Remark 50M->50M(224M) 2.348ms
          [9.276s][info][gc] GC(10) Pause Cleanup 50M->50M(224M) 0.036ms
          [9.276s][info][gc] GC(10) Concurrent Mark Cycle 81.067ms
          [183.531s][info][gc] GC(112) Pause Young (Normal) (G1 Evacuation Pause) 25100M->23708M(32720M) 61.886ms
          [10.978s][info][gc] GC(11) Pause Young (Normal) (G1 Evacuation Pause) 126M->57M(224M) 6.612ms
          [12.987s][info][gc] GC(12) Pause Young (Normal) (GCLocker Initiated GC) 134M->69M(224M) 9.084ms
          [185.817s][info][gc] GC(113) Pause Young (Normal) (G1 Evacuation Pause) 25196M->23786M(32720M) 97.743ms
          [14.019s][info][gc] GC(13) Pause Young (Normal) (G1 Evacuation Pause) 133M->85M(224M) 8.653ms
          [187.602s][info][gc] GC(114) Pause Young (Normal) (G1 Evacuation Pause) 25290M->23840M(32720M) 57.743ms
          [188.583s][info][gc] GC(115) Pause Young (Normal) (G1 Evacuation Pause) 25328M->23888M(32720M) 66.449ms
          [16.337s][info][gc] GC(14) Pause Young (Normal) (G1 Evacuation Pause) 133M->94M(224M) 8.514ms
          [16.500s][info][gc] GC(15) Pause Young (Normal) (G1 Evacuation Pause) 126M->103M(224M) 7.683ms
          [16.637s][info][gc] GC(16) Pause Young (Normal) (G1 Evacuation Pause) 135M->113M(224M) 7.560ms
          [16.785s][info][gc] GC(17) Pause Young (Concurrent Start) (G1 Evacuation Pause) 145M->124M(624M) 16.403ms
          [16.785s][info][gc] GC(18) Concurrent Mark Cycle
          [16.873s][info][gc] GC(18) Pause Remark 150M->150M(592M) 2.644ms
          [16.916s][info][gc] GC(18) Pause Cleanup 166M->166M(592M) 0.036ms
          [16.918s][info][gc] GC(18) Concurrent Mark Cycle 133.488ms
          [17.503s][info][gc] GC(19) Pause Young (Normal) (G1 Evacuation Pause) 348M->201M(592M) 40.339ms
          [17.882s][info][gc] GC(20) Pause Young (Normal) (G1 Evacuation Pause) 361M->269M(592M) 32.680ms
          [190.705s][info][gc] GC(116) Pause Young (Normal) (G1 Evacuation Pause) 25408M->24001M(32720M) 77.402ms
          [190.874s][info][gc] GC(111) Pause Remark 24153M->19033M(32720M) 4.596ms
          [18.320s][info][gc] GC(21) Pause Young (Normal) (G1 Evacuation Pause) 381M->305M(592M) 27.555ms
          [18.665s][info][gc] GC(22) Pause Young (Concurrent Start) (G1 Evacuation Pause) 401M->336M(592M) 29.390ms
          [18.665s][info][gc] GC(23) Concurrent Mark Cycle
          [18.847s][info][gc] GC(23) Pause Remark 393M->393M(704M) 4.156ms
          [18.955s][info][gc] GC(23) Pause Cleanup 430M->430M(704M) 0.039ms
          [18.958s][info][gc] GC(23) Concurrent Mark Cycle 292.423ms
          [18.984s][info][gc] GC(24) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 432M->368M(704M) 20.312ms
          [19.089s][info][gc] GC(25) Pause Young (Mixed) (G1 Evacuation Pause) 448M->423M(1904M) 54.476ms
          [191.928s][info][gc] GC(117) Pause Young (Normal) (G1 Evacuation Pause) 20305M->18963M(32720M) 88.601ms
          [23.312s][info][gc] GC(26) Pause Young (Normal) (G1 Evacuation Pause) 1303M->683M(1904M) 104.727ms
          [196.176s][info][gc] GC(111) Pause Cleanup 20771M->20771M(32720M) 0.656ms
          [196.194s][info][gc] GC(111) Concurrent Mark Cycle 14355.652ms
          [24.644s][info][gc] GC(27) Pause Young (Normal) (G1 Evacuation Pause) 1259M->941M(1904M) 110.089ms
          [25.658s][info][gc] GC(28) Pause Young (Normal) (G1 Evacuation Pause) 1325M->1066M(1904M) 82.200ms
          [198.612s][info][gc] GC(118) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 22275M->19253M(32720M) 158.866ms
          [26.689s][info][gc] GC(29) Pause Young (Normal) (G1 Evacuation Pause) 1402M->1168M(4432M) 107.551ms
          [28.629s][info][gc] GC(30) Pause Young (Normal) (G1 Evacuation Pause) 2096M->1584M(4432M) 132.371ms
          [201.908s][info][gc] GC(119) Pause Young (Mixed) (G1 Evacuation Pause) 20597M->17479M(32720M) 201.785ms
          [30.841s][info][gc] GC(31) Pause Young (Normal) (G1 Evacuation Pause) 2432M->1837M(4432M) 144.054ms
          [204.079s][info][gc] GC(120) Pause Young (Mixed) (G1 Evacuation Pause) 19063M->16581M(32720M) 219.466ms
          [32.837s][info][gc] GC(32) Pause Young (Normal) (G1 Evacuation Pause) 2637M->2095M(4432M) 144.204ms
          [206.629s][info][gc] GC(121) Pause Young (Mixed) (G1 Evacuation Pause) 18197M->15963M(32720M) 239.945ms
          [209.642s][info][gc] GC(122) Pause Young (Mixed) (G1 Evacuation Pause) 17547M->15358M(32720M) 324.130ms
          [216.205s][info][gc] GC(123) Pause Young (Normal) (G1 Evacuation Pause) 21726M->15471M(32720M) 112.898ms
          [222.005s][info][gc] GC(124) Pause Young (Normal) (G1 Evacuation Pause) 20319M->15680M(32720M) 175.095ms
          [229.518s][info][gc] GC(125) Pause Young (Normal) (G1 Evacuation Pause) 19888M->16003M(32720M) 183.697ms
          [232.048s][info][gc] GC(126) Pause Young (Normal) (G1 Evacuation Pause) 18339M->16047M(32720M) 147.263ms
          [236.986s][info][gc] GC(127) Pause Young (Normal) (G1 Evacuation Pause) 22703M->16047M(32720M) 32.271ms
          [242.758s][info][gc] GC(128) Pause Young (Normal) (G1 Evacuation Pause) 23471M->16080M(32720M) 34.024ms
          [251.262s][info][gc] GC(129) Pause Young (Concurrent Start) (G1 Humongous Allocation) 21705M->16217M(32720M) 85.060ms
          [251.262s][info][gc] GC(130) Concurrent Mark Cycle
          [258.114s][info][gc] GC(130) Pause Remark 20689M->20353M(32720M) 3.153ms
          [262.347s][info][gc] GC(130) Pause Cleanup 22473M->22473M(32720M) 0.958ms
          [262.366s][info][gc] GC(130) Concurrent Mark Cycle 11104.568ms
          [264.881s][info][gc] GC(131) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 23865M->16634M(32720M) 330.284ms
          [266.814s][info][gc] GC(132) Pause Young (Mixed) (G1 Evacuation Pause) 17626M->16408M(32720M) 336.870ms
          [272.412s][info][gc] GC(133) Pause Young (Normal) (G1 Evacuation Pause) 20120M->16984M(32720M) 212.262ms
          [275.024s][info][gc] GC(134) Pause Young (Normal) (G1 Evacuation Pause) 18248M->17259M(32720M) 214.229ms
          [277.728s][info][gc] GC(135) Pause Young (Normal) (G1 Evacuation Pause) 19003M->17541M(32720M) 127.313ms
          [280.761s][info][gc] GC(136) Pause Young (Normal) (G1 Evacuation Pause) 19317M->17742M(32720M) 120.522ms
          [283.316s][info][gc] GC(137) Pause Young (Normal) (G1 Evacuation Pause) 20318M->17884M(32720M) 94.388ms
          [285.368s][info][gc] GC(138) Pause Young (Normal) (G1 Evacuation Pause) 19980M->18024M(32720M) 151.635ms
          [288.472s][info][gc] GC(139) Pause Young (Normal) (G1 Evacuation Pause) 20920M->18114M(32720M) 98.318ms
          [290.693s][info][gc] GC(140) Pause Young (Normal) (G1 Evacuation Pause) 20642M->18155M(32720M) 97.173ms
          [297.300s][info][gc] GC(141) Pause Young (Normal) (G1 Evacuation Pause) 27083M->18166M(32720M) 45.847ms
          [307.418s][info][gc] GC(142) Pause Young (Concurrent Start) (G1 Evacuation Pause) 28710M->18201M(32720M) 55.609ms
          [307.418s][info][gc] GC(143) Concurrent Mark Cycle
          [314.054s][info][gc] GC(143) Pause Remark 22761M->21097M(32720M) 3.313ms
          [318.754s][info][gc] GC(143) Pause Cleanup 25657M->25657M(32720M) 1.209ms
          [318.776s][info][gc] GC(143) Concurrent Mark Cycle 11357.872ms
          [320.445s][info][gc] GC(144) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 27193M->16666M(32720M) 105.511ms
          [322.395s][info][gc] GC(145) Pause Young (Mixed) (G1 Evacuation Pause) 18026M->15963M(32720M) 165.582ms
          [351.135s][info][gc] GC(146) Pause Young (Normal) (G1 Evacuation Pause) 29611M->17560M(32720M) 543.695ms
          [352.925s][info][gc] GC(147) Pause Young (Normal) (G1 Evacuation Pause) 18104M->17625M(32720M) 347.448ms
          [0.009s][info][gc] Using G1
          [1.087s][info][gc] GC(0) Pause Young (Normal) (G1 Evacuation Pause) 48M->17M(1024M) 6.844ms
          [1.286s][info][gc] GC(1) Pause Young (Concurrent Start) (Metadata GC Threshold) 27M->19M(1024M) 6.220ms
          [1.286s][info][gc] GC(2) Concurrent Mark Cycle
          [1.293s][info][gc] GC(2) Pause Remark 19M->19M(224M) 0.741ms
          [1.297s][info][gc] GC(2) Pause Cleanup 19M->19M(224M) 0.030ms
          [1.298s][info][gc] GC(2) Concurrent Mark Cycle 12.054ms
          [2.331s][info][gc] GC(3) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 51M->24M(224M) 3.963ms
          [2.562s][info][gc] GC(4) Pause Young (Mixed) (G1 Evacuation Pause) 40M->25M(224M) 3.735ms
          [4.000s][info][gc] GC(5) Pause Young (Concurrent Start) (Metadata GC Threshold) 89M->33M(224M) 11.074ms
          [4.000s][info][gc] GC(6) Concurrent Mark Cycle
          [4.026s][info][gc] GC(6) Pause Remark 35M->35M(224M) 1.806ms
          [4.030s][info][gc] GC(6) Pause Cleanup 36M->36M(224M) 0.038ms
          [4.032s][info][gc] GC(6) Concurrent Mark Cycle 31.805ms
          [5.360s][info][gc] GC(7) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 97M->39M(224M) 9.101ms
          [7.396s][info][gc] GC(8) Pause Young (Mixed) (G1 Evacuation Pause) 55M->41M(224M) 6.572ms
          [8.187s][info][gc] GC(9) Pause Young (Concurrent Start) (Metadata GC Threshold) 92M->47M(224M) 6.530ms
          [8.187s][info][gc] GC(10) Concurrent Mark Cycle
          [8.217s][info][gc] GC(10) Pause Remark 51M->51M(224M) 1.725ms
          [8.231s][info][gc] GC(10) Pause Cleanup 53M->53M(224M) 0.053ms
          [8.231s][info][gc] GC(10) Concurrent Mark Cycle 44.148ms
          [9.346s][info][gc] GC(11) Pause Young (Concurrent Start) (G1 Evacuation Pause) 127M->59M(224M) 9.714ms
          [9.346s][info][gc] GC(12) Concurrent Mark Cycle
          [9.388s][info][gc] GC(12) Pause Remark 60M->60M(224M) 2.117ms
          [9.402s][info][gc] GC(12) Pause Cleanup 62M->62M(224M) 0.030ms
          [9.402s][info][gc] GC(12) Concurrent Mark Cycle 56.057ms
          [11.067s][info][gc] GC(13) Pause Young (Normal) (G1 Evacuation Pause) 139M->73M(224M) 11.054ms
          [12.256s][info][gc] GC(14) Pause Young (Normal) (G1 Evacuation Pause) 137M->86M(224M) 7.487ms
          [21.362s][info][gc] GC(15) Pause Young (Normal) (G1 Evacuation Pause) 134M->101M(224M) 8.137ms
          [21.533s][info][gc] GC(16) Pause Young (Normal) (G1 Evacuation Pause) 133M->114M(224M) 6.377ms
          [21.620s][info][gc] GC(17) Pause Young (Concurrent Start) (G1 Evacuation Pause) 146M->124M(224M) 7.061ms
          [21.620s][info][gc] GC(18) Concurrent Mark Cycle
          [21.685s][info][gc] GC(19) Pause Young (Normal) (G1 Evacuation Pause) 140M->129M(224M) 5.534ms
          [21.696s][info][gc] GC(18) Pause Remark 131M->131M(272M) 4.227ms
          [21.729s][info][gc] GC(20) Pause Young (Normal) (G1 Evacuation Pause) 143M->135M(272M) 7.358ms
          [21.739s][info][gc] GC(18) Pause Cleanup 139M->139M(272M) 0.051ms
          [21.739s][info][gc] GC(18) Concurrent Mark Cycle 118.766ms
          [21.870s][info][gc] GC(21) Pause Young (Normal) (G1 Evacuation Pause) 183M->150M(272M) 10.065ms
          [21.927s][info][gc] GC(22) Pause Young (Concurrent Start) (G1 Evacuation Pause) 182M->160M(272M) 8.171ms
          [21.927s][info][gc] GC(23) Concurrent Mark Cycle
          [21.959s][info][gc] GC(24) Pause Young (Normal) (G1 Evacuation Pause) 176M->165M(272M) 6.206ms
          [21.989s][info][gc] GC(25) Pause Young (Normal) (G1 Evacuation Pause) 179M->174M(672M) 11.269ms
          [22.020s][info][gc] GC(23) Pause Remark 197M->197M(672M) 2.277ms
          [22.061s][info][gc] GC(23) Pause Cleanup 217M->217M(672M) 0.038ms
          [22.063s][info][gc] GC(23) Concurrent Mark Cycle 136.663ms
          [22.412s][info][gc] GC(26) Pause Young (Normal) (G1 Evacuation Pause) 381M->233M(672M) 25.546ms
          [22.718s][info][gc] GC(27) Pause Young (Normal) (G1 Evacuation Pause) 425M->305M(672M) 25.425ms
          [22.926s][info][gc] GC(28) Pause Young (Normal) (G1 Evacuation Pause) 433M->348M(672M) 24.190ms
          [23.084s][info][gc] GC(29) Pause Young (Concurrent Start) (G1 Humongous Allocation) 449M->380M(672M) 19.186ms
          [23.084s][info][gc] GC(30) Concurrent Mark Cycle
          [23.228s][info][gc] GC(30) Pause Remark 503M->503M(864M) 26.570ms
          [23.332s][info][gc] GC(30) Pause Cleanup 551M->551M(864M) 0.086ms
          [23.335s][info][gc] GC(30) Concurrent Mark Cycle 250.885ms
          [23.371s][info][gc] GC(31) Pause Young (Normal) (G1 Evacuation Pause) 556M->478M(864M) 25.707ms
          [23.692s][info][gc] GC(32) Pause Young (Concurrent Start) (G1 Evacuation Pause) 638M->527M(2352M) 50.117ms
          [23.692s][info][gc] GC(33) Concurrent Mark Cycle
          [23.911s][info][gc] GC(33) Pause Remark 615M->583M(1984M) 2.366ms
          [24.031s][info][gc] GC(33) Pause Cleanup 631M->631M(1984M) 0.103ms
          [24.036s][info][gc] GC(33) Concurrent Mark Cycle 344.443ms
          [25.867s][info][gc] GC(34) Pause Young (Normal) (G1 Evacuation Pause) 1503M->869M(1984M) 125.479ms
          [26.827s][info][gc] GC(35) Pause Young (Normal) (G1 Evacuation Pause) 1301M->1006M(1984M) 94.541ms
          [27.603s][info][gc] GC(36) Pause Young (Concurrent Start) (GCLocker Initiated GC) 1390M->1134M(1984M) 70.266ms
          [27.603s][info][gc] GC(37) Concurrent Mark Cycle
          [28.103s][info][gc] GC(37) Pause Remark 1321M->1257M(2112M) 3.762ms
          [28.469s][info][gc] GC(37) Pause Cleanup 1356M->1356M(2112M) 0.120ms
          [28.475s][info][gc] GC(37) Concurrent Mark Cycle 871.697ms
          [28.713s][info][gc] GC(38) Pause Young (Concurrent Start) (G1 Humongous Allocation) 1429M->1241M(2112M) 75.121ms
          [28.713s][info][gc] GC(39) Concurrent Mark Cycle
          [29.171s][info][gc] GC(39) Pause Remark 1609M->1593M(2672M) 105.697ms
          [29.592s][info][gc] GC(39) Pause Cleanup 1751M->1751M(2672M) 0.153ms
          [29.596s][info][gc] GC(39) Concurrent Mark Cycle 883.441ms
          [29.757s][info][gc] GC(40) Pause Young (Normal) (G1 Evacuation Pause) 1801M->1554M(2672M) 65.727ms
          [30.789s][info][gc] GC(41) Pause Young (Concurrent Start) (G1 Evacuation Pause) 2034M->1703M(2672M) 71.080ms
          [30.789s][info][gc] GC(42) Concurrent Mark Cycle
          [31.473s][info][gc] GC(42) Pause Remark 2022M->1926M(3232M) 12.418ms
          [31.843s][info][gc] GC(43) Pause Young (Normal) (G1 Evacuation Pause) 2007M->1736M(6800M) 123.322ms
          [32.080s][info][gc] GC(42) Pause Cleanup 1816M->1816M(6800M) 0.158ms
          [32.101s][info][gc] GC(42) Concurrent Mark Cycle 1312.228ms
          [34.890s][info][gc] GC(44) Pause Young (Normal) (G1 Evacuation Pause) 3016M->2111M(6800M) 155.587ms
          [36.578s][info][gc] GC(45) Pause Young (Normal) (G1 Evacuation Pause) 3343M->2762M(6800M) 165.523ms
          [38.735s][info][gc] GC(46) Pause Young (Normal) (G1 Evacuation Pause) 3690M->3119M(6800M) 180.880ms
          [40.080s][info][gc] GC(47) Pause Young (Normal) (G1 Evacuation Pause) 3743M->3318M(6800M) 111.992ms
          [42.272s][info][gc] GC(48) Pause Young (Concurrent Start) (G1 Evacuation Pause) 4422M->3658M(10048M) 222.122ms
          [42.272s][info][gc] GC(49) Concurrent Mark Cycle
          [43.734s][info][gc] GC(49) Pause Remark 4250M->4042M(10048M) 2.827ms
          [44.174s][info][gc] GC(50) Pause Young (Normal) (G1 Evacuation Pause) 4154M->3660M(10048M) 143.031ms
          [45.140s][info][gc] GC(49) Pause Cleanup 4132M->4132M(10048M) 0.325ms
          [45.172s][info][gc] GC(49) Concurrent Mark Cycle 2900.058ms
          [46.464s][info][gc] GC(51) Pause Young (Normal) (G1 Evacuation Pause) 4524M->3999M(10048M) 196.891ms
          [47.214s][info][gc] GC(52) Pause Young (Normal) (G1 Evacuation Pause) 4367M->4127M(10048M) 111.479ms
          [48.914s][info][gc] GC(53) Pause Young (Normal) (G1 Evacuation Pause) 5055M->4398M(10048M) 132.615ms
          [49.996s][info][gc] GC(54) Pause Young (Concurrent Start) (G1 Humongous Allocation) 4926M->4607M(10048M) 96.548ms
          [49.996s][info][gc] GC(55) Concurrent Undo Cycle
          [50.003s][info][gc] GC(55) Concurrent Undo Cycle 6.920ms
          [50.279s][info][gc] GC(56) Pause Young (Concurrent Start) (G1 Humongous Allocation) 4976M->4994M(14112M) 112.698ms
          [50.279s][info][gc] GC(57) Concurrent Undo Cycle
          [50.303s][info][gc] GC(57) Concurrent Undo Cycle 23.949ms
          [54.226s][info][gc] GC(58) Pause Young (Normal) (G1 Evacuation Pause) 6850M->5773M(14112M) 160.043ms
          [55.302s][info][gc] GC(59) Pause Young (Normal) (G1 Evacuation Pause) 6317M->5965M(14112M) 115.555ms
          [57.308s][info][gc] GC(60) Pause Young (Normal) (G1 Evacuation Pause) 7101M->6303M(14112M) 141.262ms
          [59.593s][info][gc] GC(61) Pause Young (Normal) (G1 Evacuation Pause) 7375M->6684M(14112M) 177.255ms
          [61.606s][info][gc] GC(62) Pause Young (Concurrent Start) (G1 Evacuation Pause) 7548M->6974M(17840M) 289.168ms
          [61.606s][info][gc] GC(63) Concurrent Mark Cycle
          [63.976s][info][gc] GC(64) Pause Young (Normal) (G1 Evacuation Pause) 7758M->7251M(17840M) 218.176ms
          [64.928s][info][gc] GC(63) Pause Remark 7643M->7227M(17840M) 2.942ms
          [65.934s][info][gc] GC(65) Pause Young (Normal) (G1 Evacuation Pause) 7603M->7087M(17840M) 142.914ms
          [67.903s][info][gc] GC(66) Pause Young (Normal) (G1 Evacuation Pause) 7887M->7367M(17840M) 160.716ms
          [67.984s][info][gc] GC(63) Pause Cleanup 7391M->7391M(17840M) 0.319ms
          [68.033s][info][gc] GC(63) Concurrent Mark Cycle 6427.229ms
          [69.948s][info][gc] GC(67) Pause Young (Normal) (G1 Evacuation Pause) 8167M->7685M(17840M) 165.165ms
          [72.078s][info][gc] GC(68) Pause Young (Normal) (G1 Evacuation Pause) 8565M->8077M(17840M) 192.748ms
          [74.217s][info][gc] GC(69) Pause Young (Normal) (GCLocker Initiated GC) 8925M->8471M(19328M) 202.333ms
          [76.435s][info][gc] GC(70) Pause Young (Normal) (G1 Evacuation Pause) 9303M->8791M(19328M) 246.768ms
          [78.784s][info][gc] GC(71) Pause Young (Normal) (G1 Evacuation Pause) 9623M->9223M(19328M) 301.747ms
          [80.796s][info][gc] GC(72) Pause Young (Concurrent Start) (G1 Evacuation Pause) 10055M->9583M(19328M) 158.341ms
          [80.796s][info][gc] GC(73) Concurrent Mark Cycle
          [83.746s][info][gc] GC(74) Pause Young (Normal) (G1 Evacuation Pause) 11951M->11384M(20256M) 180.187ms
          [85.292s][info][gc] GC(73) Pause Remark 11912M->11912M(20256M) 2.913ms
          [86.447s][info][gc] GC(75) Pause Young (Normal) (G1 Evacuation Pause) 12264M->11679M(20256M) 176.573ms
          [88.435s][info][gc] GC(76) Pause Young (Normal) (G1 Evacuation Pause) 12575M->11967M(20256M) 171.686ms
          [89.366s][info][gc] GC(73) Pause Cleanup 12447M->12447M(20256M) 0.660ms
          [89.401s][info][gc] GC(73) Concurrent Mark Cycle 8605.430ms
          [90.212s][info][gc] GC(77) Pause Young (Normal) (G1 Evacuation Pause) 12847M->12262M(20256M) 140.674ms
          [91.002s][info][gc] GC(78) Pause Young (Concurrent Start) (G1 Humongous Allocation) 12622M->12412M(20256M) 141.485ms
          [91.002s][info][gc] GC(79) Concurrent Mark Cycle
          [93.938s][info][gc] GC(80) Pause Young (Normal) (G1 Evacuation Pause) 13388M->12799M(20256M) 173.392ms
          [96.372s][info][gc] GC(79) Pause Remark 13671M->12935M(21584M) 24.021ms
          [96.636s][info][gc] GC(81) Pause Young (Normal) (G1 Evacuation Pause) 12943M->12556M(21584M) 245.061ms
          [99.918s][info][gc] GC(82) Pause Young (Normal) (G1 Evacuation Pause) 13500M->13239M(26048M) 216.741ms
          [100.471s][info][gc] GC(79) Pause Cleanup 13415M->13415M(26048M) 0.572ms
          [100.517s][info][gc] GC(79) Concurrent Mark Cycle 9515.541ms
          [103.382s][info][gc] GC(83) Pause Young (Normal) (G1 Evacuation Pause) 14391M->13927M(26048M) 194.256ms
          [106.256s][info][gc] GC(84) Pause Young (Concurrent Start) (G1 Evacuation Pause) 15047M->14591M(26048M) 178.244ms
          [106.256s][info][gc] GC(85) Concurrent Mark Cycle
          [108.838s][info][gc] GC(86) Pause Young (Normal) (G1 Evacuation Pause) 15775M->15039M(26048M) 173.942ms
          [111.203s][info][gc] GC(87) Pause Young (Normal) (G1 Evacuation Pause) 16159M->15407M(26048M) 168.347ms
          [112.519s][info][gc] GC(85) Pause Remark 16055M->16023M(26720M) 13.528ms
          [113.970s][info][gc] GC(88) Pause Young (Normal) (G1 Evacuation Pause) 16527M->15767M(26720M) 213.835ms
          [116.262s][info][gc] GC(89) Pause Young (Normal) (G1 Evacuation Pause) 16919M->16143M(26720M) 183.711ms
          [117.197s][info][gc] GC(85) Pause Cleanup 16679M->16679M(26720M) 0.643ms
          [117.236s][info][gc] GC(85) Concurrent Mark Cycle 10979.262ms
          [118.408s][info][gc] GC(90) Pause Young (Normal) (G1 Evacuation Pause) 17295M->16527M(26720M) 186.103ms
          [120.482s][info][gc] GC(91) Pause Young (Concurrent Start) (G1 Evacuation Pause) 17679M->16919M(26720M) 205.874ms
          [120.482s][info][gc] GC(92) Concurrent Mark Cycle
          [125.616s][info][gc] GC(93) Pause Young (Normal) (G1 Evacuation Pause) 18359M->17759M(26720M) 306.702ms
          [127.706s][info][gc] GC(92) Pause Remark 18455M->18455M(30784M) 71.037ms
          [129.601s][info][gc] GC(94) Pause Young (Normal) (G1 Evacuation Pause) 18975M->18271M(30784M) 386.859ms
          [133.423s][info][gc] GC(92) Pause Cleanup 19567M->19567M(30784M) 0.947ms
          [133.459s][info][gc] GC(92) Concurrent Mark Cycle 12976.850ms
          [133.930s][info][gc] GC(95) Pause Young (Normal) (G1 Evacuation Pause) 19631M->18839M(30784M) 204.000ms
          [136.520s][info][gc] GC(96) Pause Young (Concurrent Start) (G1 Humongous Allocation) 20059M->19303M(31200M) 207.826ms
          [136.520s][info][gc] GC(97) Concurrent Mark Cycle
          [140.526s][info][gc] GC(98) Pause Young (Normal) (G1 Evacuation Pause) 20711M->19831M(31200M) 360.661ms
          [144.259s][info][gc] GC(99) Pause Young (Normal) (G1 Evacuation Pause) 21175M->20311M(31200M) 568.142ms
          [145.216s][info][gc] GC(97) Pause Remark 20663M->20519M(32720M) 25.442ms
          [148.371s][info][gc] GC(100) Pause Young (Normal) (G1 Evacuation Pause) 21511M->20655M(32720M) 435.807ms
          [151.922s][info][gc] GC(97) Pause Cleanup 24623M->24623M(32720M) 0.939ms
          [151.963s][info][gc] GC(97) Concurrent Mark Cycle 15442.658ms
          [154.637s][info][gc] GC(101) Pause Young (Concurrent Start) (G1 Humongous Allocation) 24911M->24007M(32720M) 546.709ms
          [154.637s][info][gc] GC(102) Concurrent Mark Cycle
          [158.179s][info][gc] GC(103) Pause Young (Normal) (G1 Evacuation Pause) 25463M->24679M(32720M) 752.903ms
          [169.722s][info][gc] GC(102) Pause Remark 25544M->24104M(32720M) 3.131ms
          [175.441s][info][gc] GC(104) Pause Young (Normal) (G1 Evacuation Pause) 24663M->23434M(32720M) 339.224ms
          [176.902s][info][gc] GC(102) Pause Cleanup 24058M->24058M(32720M) 1.316ms
          [176.928s][info][gc] GC(102) Concurrent Mark Cycle 22290.938ms
          [177.704s][info][gc] GC(105) Pause Young (Normal) (G1 Evacuation Pause) 24906M->23541M(32720M) 138.947ms
          [178.738s][info][gc] GC(106) Pause Young (Concurrent Start) (G1 Evacuation Pause) 25061M->23612M(32720M) 58.757ms
          [178.738s][info][gc] GC(107) Concurrent Mark Cycle
          [179.720s][info][gc] GC(108) Pause Young (Normal) (G1 Evacuation Pause) 25052M->23667M(32720M) 59.342ms
          [181.006s][info][gc] GC(109) Pause Young (Normal) (G1 Evacuation Pause) 25155M->23742M(32720M) 57.012ms
          [181.952s][info][gc] GC(110) Pause Young (Normal) (G1 Evacuation Pause) 25246M->23797M(32720M) 50.317ms
          [182.876s][info][gc] GC(111) Pause Young (Normal) (G1 Evacuation Pause) 25285M->23837M(32720M) 51.539ms
          [184.921s][info][gc] GC(112) Pause Young (Normal) (G1 Evacuation Pause) 26061M->23994M(32720M) 98.326ms
          [185.159s][info][gc] GC(107) Pause Remark 24338M->18754M(32720M) 5.052ms
          [187.679s][info][gc] GC(113) Pause Young (Normal) (G1 Evacuation Pause) 20842M->18686M(32720M) 161.459ms
          [189.565s][info][gc] GC(107) Pause Cleanup 19742M->19742M(32720M) 0.710ms
          [189.589s][info][gc] GC(107) Concurrent Mark Cycle 10850.442ms
          [190.968s][info][gc] GC(114) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 20414M->18770M(32720M) 138.524ms
          [194.149s][info][gc] GC(115) Pause Young (Mixed) (G1 Evacuation Pause) 20322M->17114M(32720M) 202.149ms
          [196.353s][info][gc] GC(116) Pause Young (Mixed) (G1 Evacuation Pause) 18698M->16379M(32720M) 260.401ms
          [198.755s][info][gc] GC(117) Pause Young (Mixed) (G1 Evacuation Pause) 17947M->15777M(32720M) 219.168ms
          [201.357s][info][gc] GC(118) Pause Young (Mixed) (G1 Evacuation Pause) 17345M->15251M(32720M) 313.879ms
          [207.233s][info][gc] GC(119) Pause Young (Normal) (G1 Evacuation Pause) 20787M->15380M(32720M) 125.973ms
          [213.285s][info][gc] GC(120) Pause Young (Concurrent Start) (G1 Humongous Allocation) 23836M->15474M(32720M) 74.469ms
          [213.285s][info][gc] GC(121) Concurrent Mark Cycle
          [219.381s][info][gc] GC(121) Pause Remark 18053M->17957M(32720M) 3.506ms
          [223.411s][info][gc] GC(121) Pause Cleanup 20762M->20762M(32720M) 1.366ms
          [223.432s][info][gc] GC(121) Concurrent Mark Cycle 10147.637ms
          [224.192s][info][gc] GC(122) Pause Young (Normal) (G1 Evacuation Pause) 21458M->15826M(32720M) 213.297ms
          [227.879s][info][gc] GC(123) Pause Young (Normal) (G1 Evacuation Pause) 20034M->15876M(32720M) 158.641ms
          [232.402s][info][gc] GC(124) Pause Young (Normal) (G1 Evacuation Pause) 22196M->15862M(32720M) 27.601ms
          [238.290s][info][gc] GC(125) Pause Young (Normal) (G1 Evacuation Pause) 22598M->15939M(32720M) 50.125ms
          [248.596s][info][gc] GC(126) Pause Young (Normal) (G1 Evacuation Pause) 22963M->16186M(32720M) 123.521ms
          [258.411s][info][gc] GC(127) Pause Young (Normal) (G1 Evacuation Pause) 21674M->16994M(32720M) 339.662ms
          [260.200s][info][gc] GC(128) Pause Young (Normal) (G1 Evacuation Pause) 18002M->17249M(32720M) 286.778ms
          [262.926s][info][gc] GC(129) Pause Young (Normal) (G1 Evacuation Pause) 18785M->17486M(32720M) 111.986ms
          [265.571s][info][gc] GC(130) Pause Young (Normal) (G1 Evacuation Pause) 19022M->17701M(32720M) 116.650ms
          [269.021s][info][gc] GC(131) Pause Young (Normal) (G1 Evacuation Pause) 19541M->18031M(32720M) 137.131ms
          [272.240s][info][gc] GC(132) Pause Young (Normal) (G1 Evacuation Pause) 19679M->18323M(32720M) 153.375ms
          [273.940s][info][gc] GC(133) Pause Young (Normal) (G1 Evacuation Pause) 19891M->18349M(32720M) 70.087ms
          [277.744s][info][gc] GC(134) Pause Young (Normal) (G1 Evacuation Pause) 22301M->18606M(32720M) 103.136ms
          [279.611s][info][gc] GC(135) Pause Young (Normal) (G1 Evacuation Pause) 20782M->18709M(32720M) 101.431ms
          [283.995s][info][gc] GC(136) Pause Young (Normal) (G1 Evacuation Pause) 23125M->18746M(32720M) 41.653ms
          [288.190s][info][gc] GC(137) Pause Young (Normal) (G1 Evacuation Pause) 24458M->18752M(32720M) 41.717ms
          [294.966s][info][gc] GC(138) Pause Young (Normal) (G1 Evacuation Pause) 26688M->18784M(32720M) 55.624ms
          [305.158s][info][gc] GC(139) Pause Young (Normal) (G1 Evacuation Pause) 28384M->18799M(32720M) 58.891ms
          [307.582s][info][gc] GC(140) Pause Young (Concurrent Start) (G1 Humongous Allocation) 21583M->18880M(32720M) 78.174ms
          [307.582s][info][gc] GC(141) Concurrent Mark Cycle
          [314.246s][info][gc] GC(141) Pause Remark 23336M->21560M(32720M) 3.362ms
          [318.574s][info][gc] GC(141) Pause Cleanup 24584M->24584M(32720M) 1.186ms
          [318.597s][info][gc] GC(141) Concurrent Mark Cycle 11015.046ms
          [325.853s][info][gc] GC(142) Pause Young (Prepare Mixed) (G1 Evacuation Pause) 27552M->18272M(32720M) 452.950ms
          [327.840s][info][gc] GC(143) Pause Young (Mixed) (G1 Evacuation Pause) 18992M->17780M(32720M) 385.858ms
          [331.258s][info][gc] GC(144) Pause Young (Mixed) (G1 Evacuation Pause) 19348M->17471M(32720M) 188.406ms
          [337.429s][info][gc] GC(145) Pause Young (Normal) (G1 Evacuation Pause) 19567M->17553M(32720M) 406.946ms
          [343.617s][info][gc] GC(146) Pause Young (Normal) (G1 Evacuation Pause) 19825M->17620M(32720M) 81.008ms
          [353.134s][info][gc] GC(147) Pause Young (Normal) (G1 Evacuation Pause) 21172M->17771M(32720M) 128.226ms
          [356.622s][info][gc] GC(148) Pause Young (Normal) (G1 Evacuation Pause) 19115M->17881M(32720M) 175.742ms
          error.log
          marrask. 26, 2021 12:52:24 IP. com.sun.javafx.application.PlatformImpl startup
          WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @55f3c410'
          marrask. 26, 2021 12:55:13 IP. com.sun.javafx.application.PlatformImpl startup
          marrask. 26, 2021 1:00:46 IP. com.sun.javafx.application.PlatformImpl startup
          WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @f9b7332'
          • pejotuP Offline
            pejotuP Offline
            pejotu
            @lasse-lindqvist I noted from the logs that I might check my graphics driver version -
            so i revereted to an earlier stable version, and
            1. cleared the logs
            2. On virtual desktop 1, at 13:27 I opened the same model as earlier - this time no crash.
            3. Still on virtual desktop 1, at 13:36 I opened a second instance of Solibri, and started opening the second model - this time, tehe second instance crashes at about 4% loading the model.
            4. Instance 1 is still running fine, and I attempted to open model 2 in a second instance again, and it still crashes.
            runtime.log
            13:27:04.220 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
            13:27:04.225 [main] INFO  com.solibri.saf.core.Application - Java version: 16
            13:27:04.225 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
            13:27:04.225 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
            13:27:04.289 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
            13:27:08.487 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 13.27.08 for 3480 seconds. License type = FLOATING
            13:27:08.489 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
            13:27:09.053 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
            13:27:10.125 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
            13:27:10.125 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
            13:27:10.125 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 472.47
            13:27:11.321 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
            13:27:12.621 [main] INFO  com.solibri.saf.core.Application - Starting application
            13:27:12.621 [main] INFO  com.solibri.saf.core.Application - Application started
            13:27:12.622 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
            13:36:46.954 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
            13:36:46.956 [main] INFO  com.solibri.saf.core.Application - Java version: 16
            13:36:46.956 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
            13:36:46.956 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
            13:36:47.018 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
            13:36:50.916 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 13.36.50 for 3480 seconds. License type = FLOATING
            13:36:50.919 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
            13:36:51.462 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
            13:36:51.944 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
            13:36:51.944 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
            13:36:51.944 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 472.47
            13:36:53.088 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
            13:36:54.293 [main] INFO  com.solibri.saf.core.Application - Starting application
            13:36:54.294 [main] INFO  com.solibri.saf.core.Application - Application started
            13:36:54.294 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
            13:37:24.124 [main] INFO  com.solibri.saf.core.Application - Solibri version: 9.12.7.24
            13:37:24.127 [main] INFO  com.solibri.saf.core.Application - Java version: 16
            13:37:24.128 [main] INFO  com.solibri.saf.core.Application - Java VM name: OpenJDK 64-Bit Server VM
            13:37:24.128 [main] INFO  com.solibri.saf.core.Application - Java VM version: 16+36
            13:37:24.205 [main] INFO  com.solibri.sae.redox.SAEClassLoader - Working dir = C:\Program Files\Solibri\SOLIBRI
            13:37:28.444 [main] INFO  com.solibri.os.integration.Heartbeat - License checked out at 26.11.2021 klo 13.37.28 for 3479 seconds. License type = FLOATING
            13:37:28.445 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri OFFICE.
            13:37:28.966 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
            13:37:29.518 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: NVIDIA Corporation
            13:37:29.518 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: Quadro M2200/PCIe/SSE2
            13:37:29.518 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.6.0 NVIDIA 472.47
            13:37:30.785 [main] INFO  com.solibri.saf.core.Application - Command line arguments parsed
            13:37:32.195 [main] INFO  com.solibri.saf.core.Application - Starting application
            13:37:32.195 [main] INFO  com.solibri.saf.core.Application - Application started
            13:37:32.195 [main] INFO  com.solibri.saf.core.Application - Showing application main frame
            error.log
            marrask. 26, 2021 1:27:11 IP. com.sun.javafx.application.PlatformImpl startup
            WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @21c64522'
            marrask. 26, 2021 1:36:53 IP. com.sun.javafx.application.PlatformImpl startup
            WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @644c78d4'
            marrask. 26, 2021 1:37:30 IP. com.sun.javafx.application.PlatformImpl startup
            WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @1bdf8190'
              So it seems that this is a Java-crash since our logs show nothing relevant. JVM crash log files are named hs_err_pid*.log and can be found either from the Solibri installation folder somewhere or alternatively the Windows TEMP folder.
              You can also start Solibri from command line using the executable in C:\Program Files\Solibri\SOLIBRI\bin. This way when it crashes it should tell you where it writes the crash file.
              Since it seems to be a JVM-crash, it also means that is is not that easy for us to fix, but also it might get fixed automatically when we do Java version updates. Currently your version uses 16, and we have an update to 17 in progress.
              If we get the crash logs and/or are able to reproduce this reliably even without using Solibri specifically, there is a good chance it will be fixed by Java developers sooner or later.
              pejotuP 1 Reply Last reply
              • pejotuP Offline
                pejotuP Offline
                pejotu
                @lasse-lindqvist Sorry, hadn’t noticed your reply again for a long while - here’s a couple of log files from Monday when I last had problems. I will track this for the next few days and see if I find some other cases.
                https://www.dropbox.com/t/jJ3ganqH1PSz5yHn
                  J 13657  org.lwjgl.opengl.GL31.nglDrawArraysInstanced(IIIIJ)V (0 bytes) @ 0x000000001c2b04fe [0x000000001c2b04a0+0x000000000000005e]
                  J 13822 c2 com.solibri.saf.plugins.java3dplugin.ardor3d.OptimizedMesh.renderVBO(Lcom/ardor3d/renderer/Renderer;Lcom/ardor3d/scenegraph/MeshData;I)V (258 bytes) @ 0x000000001c2a7580 [0x000000001c2a6dc0+0x00000000000007c0]
                  J 14631 c2 com.ardor3d.scenegraph.Mesh.render(Lcom/ardor3d/renderer/Renderer;Lcom/ardor3d/scenegraph/MeshData;)V (429 bytes) @ 0x000000001c69d9e0 [0x000000001c69d3e0+0x0000000000000600]
                  J 13866 c2 com.solibri.saf.plugins.java3dplugin.ardor3d.b.a(Lcom/ardor3d/renderer/Renderer;IZZZZ)V (808 bytes) @ 0x000000001c7a03bc [0x000000001c79f980+0x0000000000000a3c]
                  j  com.solibri.saf.plugins.java3dplugin.ardor3d.b.render(Lcom/ardor3d/renderer/Renderer;)V+91
                  j  com.ardor3d.renderer.queue.RenderQueue.renderBuckets(Lcom/ardor3d/renderer/Renderer;)V+42
                  j  com.ardor3d.renderer.lwjgl.LwjglRenderer.renderBuckets(ZZ)V+18
                  j  com.ardor3d.renderer.lwjgl.LwjglRenderer.renderBuckets()V+3
                  j  com.ardor3d.renderer.lwjgl.LwjglRenderer.flushFrame(Z)V+1
                  j  com.solibri.saf.plugins.java3dplugin.ardor3d.g.i()V+167
                  j  com.solibri.saf.plugins.java3dplugin.ardor3d.g.l()V+71
                  j  com.solibri.saf.plugins.java3dplugin.ardor3d.g.m()V+1
                  j  com.solibri.saf.plugins.java3dplugin.ardor3d.g$$Lambda$506+0x000000087d6ad958.run()V+4
                  j  java.lang.Thread.run()V+11 java.base@16
                  siginfo: EXCEPTION_ACCESS_VIOLATION (0xc0000005), reading address 0x00000008c0ce5000
                  The crash is definitely caused by the 3D crashing.
                  It is really hard to say what is the root cause in the end since I have no way of reproducing this.
                  Could be fixable by using different GPU/driver or by us updating LWJGL (library we use in the 3D). Updating LWJGL is not a trivial effort, so we cannot easily provide an installer for you to test though.
                  • pejotuP Offline
                    pejotuP Offline
                    pejotu
                    Ok. I’ve tested with a couple of GPU drivers but no luck.
                    Would be interesting to know if other users have issues with this, or if it’s specific to for example the Nvidia Quadro M2200 GPU… I can check if there’s someone at our office that can try it out if I can find a persistent case that always runs into problems.
                    • pejotuP Offline
                      pejotuP Offline
                      pejotu
                      wrote on last edited by pejotu
                      #10
                      @lasse-lindqvist said in Solibri and Virtual Desktops:
                      hs_err_pid*.log
                      …so I did some more troubleshooting, and as a part of this I remembered having adjusted the memory cache, distributing it a little more to other drive partitions instead of holding it all on C:. (this all roughly coincided with other changes to my system, so I had multiplpe variables to check…)
                      I have now increased the maximum cache on drive C : from under 50Gb to 250Gb (it was this large on other drives earlier), and for now the problems I’ve been having seem to have cleared up. So possibly/probably this was all due to Windows memory cache running out, specifically on drive C:(?).
