  3. severity in report
severity in report
2 Posts 2 Posters 665 Views
  • Z Offline
    Z Offline
    Zeraxel
    Hi everyone.
    I need to take Severity of the issue in my coordination report in Excel file.
    But even in detailed template there is nothing about severity.
    john.lippJ 1 Reply Last reply
    • john.lippJ Offline
      john.lippJ Offline
      john.lipp
      replied to Zeraxel on last edited by
      @Zeraxel
      It appears the intention of the severity is to aid in handling issue creation rather than as a mechanism of reporting. In other words, as you manually create slides from results, you can focus on high severity results first by unmarking the others in the checking view. There is a priority field for results which serves the function that you can create your own names (“P1”, “High Severity”, etc). Alternatively, you could create a label.
      If you mark a result as accepted or rejected, it can no longer be filtered in the checking view by the severity (unless you set it back to unhandled).
      I do see the benefit of an enhancement to map severity to a label or priority field automatically either through a setting or perhaps through autorun etc.
      I would suggest posting a recommendation on the https://society.solibri.com/category/18/feature-requests page and hopefully others can up-vote and comment on the functionality.
