  4. Comparing Structural model with Production model (Incorrect component type)
2 Posts 2 Posters 398 Views
  • F Offline
    F Offline
    Fjeld89
    I am trying to figure out a way where I can compare the geometry of structural models, where one of the models is from the structural engineer, and the other model/models are from the company that produces the structural elements.
    The objective is to find out if the geometry of the elements are identical, or if there are deviations.
    The problem is that elements in the production models dont make it into Solibri with the correct component type. Instead of being either Wall or Slab, all the elements are “Building Element Part”.
    Is there a way to change the component types of the elements in the production models, so that I can compare the models with e.g. Architectural vs. Structural, where I can check if the geometry is filled in.
    Would appreciate any tips to make this process automatic.
    Best regards,
    Gestur
      BIM1337
      @Fjeld89 Did you try SOL/234/1.2?
