  3. New licensing + firewalls
9 Posts 4 Posters 2.1k Views
  • osharpO Offline
    osharpO Offline
    osharp
    hi,
    I thought we (corp) had tested the new licensing with our firewall but licenses cannot be obtained on our network - hotspot off my phone and its fine, so suspect the firewall is the issue
    Can Solibri please confirm what addresses and ports are needed for licensing to function?
    regards,
    Owen Sharp
    Principal Digital Engineer
    Laing O’Rourke Australia
    Level 21 | 100 Mount Street | North Sydney NSW 2060
    www.laingorourke.com.au
    • cpreidelC Offline
      cpreidelC Offline
      cpreidel
      Hey Owen,
      here is a list of all the ports you make sure that these are not blocked by your firewall/proxy:
      license.solibri.com (port 443)
      ws1.solibri.com (port 443)
      ws2.solibri.com (port 443)
      ws3.solibri.com (port 443)
      ws4.solibri.com (port 443)
      download.solibri.com (port 443)
      06832.tbnet1.com (port 443 and port 80)
      api.solibri.com (port 443)
      login.solibri.com (port 443)
      solution.solibri.com (port 443)
      certificates.godaddy.com (port 80)
      ssl.solibri.com (port 443)
      fonts.googleapis.com (port 443)
      fonts.gstatic.com (port 443)
      pool.ntp.org (UDP port 123)
      Kind regards
      Cornelius
      • cdaillouxC Offline
        cdaillouxC Offline
        cdailloux
        wrote on last edited by cdailloux
        Hello Cornelius, are all these adresses mandatory for all 9.10 Solibri ?
        The SSC administrator guide available in the document tab still list only those ones :
        06832.tbnet1.com (port 443)
        BR,
        Cyril
        cpreidelC 1 Reply Last reply
        • osharpO Offline
          osharpO Offline
          osharp
          hi Cornelius,
          we still have not resolved this - have been borrowing licenses via phone hotspot before rejoining office network as a workaround for the moment
          IT are not seeing any calls being blocked by our proxy, however current suspect is that SSL inspection may be the issue.
          Can you advise if SSL inspection by our proxy may cause a licensing issue?
          (they are going to send me an email with further details - will post here)
          regards,
          Owen Sharp
          • cpreidelC Offline
            cpreidelC Offline
            cpreidel
            replied to osharp on last edited by
            Hey @osharp,
            there is a new Beta test round which contains fixes related to Proxy. As I 've seen you are already registered for the Beta Testing, so please check this post here.
            KR
            Cornelius
            • cpreidelC Offline
              cpreidelC Offline
              cpreidel
              replied to cdailloux on last edited by
              Hey @cdailloux,
              yes, these ports may not be blocked otherwise the licensing communication does not work. Thanks for the notice about the SSC administrator guide - we will update the document accordingly.
              KR
              Cornelius
              • K Offline
                K Offline
                KarlF
                I am also having issues accessing Solibri Licence Server. Have tried hot-spotting from my phone, but still no luck getting around the proxy.
                Am also not given the option to run it as Solibri Everywhere, just so that I can view the models.
                Is there currently an issue with the license server being down?
                Regards,
                Karl
                • cpreidelC Offline
                  cpreidelC Offline
                  cpreidel
                  Hey @KarlF ,
                  today there has been a new release with 9.10.1 and just the week before a new version for 9.9 & 9.8 has been released. Could you please check, if these versions work now for you as these include all the proxy fix. Looking forward to your feedback!
                  Thanks
                  Cornelius
                  • K Offline
                    K Offline
                    KarlF
                    @cpreidel Thanks for the update. It appears to be working better now.
                    Regards,
                    Karl
