  4. Classification Performance Impact
classificationperformance
4 Posts 4 Posters 1.4k Views
    leopu
    We have been using Solibri classifications extensively to structurize differing model data and are very happy with the options that are provided, however there are a few performance related issues we ran into. With growing classifications and increasing dependencies between them, the program slows down incredibly to the point where a model update takes over ten minutes.
    Could you maybe give us an insight on how the classification logic works, so we can try to set them up as efficient as possible?
    Some things suspected of slowing things down are:
    • Referencing other classifications in the input filter of a classification
    • Referencing other classifications as a column in the rules tab of a classification
    • Having too many columns in the rules tab of a classification
    If we got rid of some of the classification dependencies, could that speed up the classification process?
    chrisC 1 Reply Last reply
    6
    • chrisC Offline
      chrisC Offline
      chris
      replied to leopu on last edited by
      @leopu We ran into this too. And have no solution at the moment. It is very scary for us and have lot of impact on our work… Classification is a must for us!
      @Solibrians FYI!
      • Alex.JA Offline
        Alex.JA Offline
        Alex.J
        Same here… @Solibrians ?
          manuel.furia Solibrians
          @leopu Everything you mentioned can slow down a classification. Also very important is what kind of data the classification operates on. For example, if the classification uses computed quantities, then those can take quite a while to compute, and will need to be recomputed every time a model is updated.
