  3. ITO save as / save with new name
itos
13 Posts 5 Posters 2.9k Views
    Mvandenbrink
    We are using Solibri with roles and predefined ITO’s. We used to change some settings of the predefined ITO and save it to a project folder as backup. Recently we noticed the save with new name option is greyed out. Any ideas why and how to solve it?
    M 1 Reply Last reply
      Mvandenbrink
      replied to Mvandenbrink on last edited by
      Dear @Solibrians do you have any idea how to save the ITO’s or why these options are greyed out?
      Alex.JA 1 Reply Last reply
      • Alex.JA Offline
        Alex.JA Offline
        Alex.J
        @Mvandenbrink the only thing that comes to mind is if this ITO is part of an extension. I think some extension contents (if not all) can’t be saved locally.
          Mvandenbrink
          @Alex-J it’s indeed part of our own company extension. So a greyed out save option seems right. But save with a new name should be available to save ITO’s with changed settings as a new one.
          • Alex.JA Offline
            Alex.JA Offline
            Alex.J
            wrote on last edited by Alex.J
            I ran into the same problem. If you load the ITO from the extension, it will be protected. So if you plan to edit the ITO, you should load it from a shared folder.
            It makes spontaneous improvements very tedious, hopefully this can be improved in the future
            ( @Solibrians )
              Wouldn’t it be great to simply have a “Make Copy” button for classifications, itos, filters …
              https://society.solibri.com/topic/997/new-filter-ito-duplicate-existing?_=1666896366786
              M Alex.JA 2 Replies Last reply
                Mvandenbrink
                @JSN That would do the trick indeed. Up-voted both Copy / Duplicate feature requests. I’m currently duplicating newly created ITO’s with the save with new name (including all the navigating to the right folder issues). Unfortunately this doesn’t work for ITO’s which originate from our Company Extension. Hopefully one of the @Solibrians will check all the minor feature request which will make our workflow much more efficient.
                • Alex.JA Offline
                  Alex.JA Offline
                  Alex.J
                  @JSN definitely!
                    There’s a reason why ITOs and other resources loaded from extensions are protected. If the extension is public, the resources contain intellectual property that the the resource publisher is not willing to share publicly. If it is a private resource, copying might still be not encouraged to reduce the risk of every user having their own slightly tweaked versions. For private extensions there could be a way to express that the resource can be saved. That feature is not available at the moment.
                    Alex.JA M 2 Replies Last reply
                      Mvandenbrink
                      Dear @Pasi-Paasiala if it’s to protect IP, it’s not really a very useful way of protecting the IP. For classifications we could just export the components filter and the classification rules. With ITO’s you could also export the components filter. You only need to recreate the columns.
                      We use our private extension, because shared resources with Sharepoint and Solibri are impossible. Our private company extension fixed that. Working on project there are always some changes to the ITO’s and Classifications from the extension. Would be very useful to save them. So you could reuse them in other Solibri files from the same project. Or to just create a backup when multiple people saving the same project at the same time. So please fix the Save with New name / Save As options. Would make working with ITO’s and Classifications a lot faster.
                      • Alex.JA Offline
                        Alex.JA Offline
                        Alex.J
                        #11
                        @Pasi-Paasiala said in ITO save as / save with new name:
                        Yes please!
                        Ideally, admins or owners could update and push it directly to the extension. Editing might be blocked to other users. But won’t Solibri X make private extensions unnecessary?
                        What we actually need for private shared resources is the ability of branching (like git)…
                        • Alex.JA Alex.J referenced this topic on
                          Mvandenbrink
                          replied to Pasi Paasiala on last edited by Mvandenbrink
                          #12
                          @Pasi-Paasiala Any news on this functionality becoming available on private extensions? With the recent Duplicate ITO and Classification buttons it would be very useful to save them too.
                            manuel.furia Solibrians
                            I opened a ticket about this.
