  4. Autorun problem with autoupdate and check
2 Posts 2 Posters 632 Views
    jesse.kurkinen
    Hey guys,
    I ran into a problem. I update the smc file with the autoupdate command and check the model with the check command, and with the check command, I also need to use the autocomment command for get through. How can I remove the autocomment command to get this work? The size of the Smc model is large and the autorun lasts for several hours with autocomment.
    <?xml version=“1.0” encoding=“ISO-8859-1”?>
    <batch name=“Simple Batch” default=“root”>
    <!-- This is the starting task -->
    <target name=“root”>
    <openmodel
    file=“P:\FIESP02\BS\20413858\001\Suunnitelma-asiakirjat\BIM\Tarkastus\xx_tarkastusta_varten.smc”/>
    <autoupdatemodels/>
    <check/>
    <autocomment zoom=“TRUE”/> <— dont need this, its needed for autorun success
    <savemodel
    <exit />
    </target>
    </batch>
    BR,
    Jesse
      replied to jesse.kurkinen on last edited by
      @jesse-kurkinen
      The autocomment row is not needed. You can remove that.
