  4. Bug with drag and drop column to classification
1 Posts 1 Posters 412 Views
    Mvandenbrink
    When using drag and drop to add a column to classifications there seems to be a bug. If you add a regular field like type or name this field becomes editable right away. On adding a classification as a column inside a classification this field isn’t editable. You will need to edit the column, click Ok and the field becomes editable.
