  3. BIM360 / ACC integration not working
25 Posts 7 Posters 10.1k Views
  • JeroenKoomenJ Offline
    JeroenKoomen
    @Sini-Aalto @Eric @Paul-Linder
    Are you sure about this?
    We made a case about this with Autodesk and this is the reaction we get:
    • C Offline
      C Offline
      calvin02
      Pls try to uninstall the Solibri Apps on Autodesk Construction Cloud > Account Admin Page > Apps > My Apps > Solibri > uninstall
      Then, try to install a Solibri Apps on Autodesk Construction Cloud again.
        JeroenKoomen
        @calvin02 why would i do that?
        It is working right now, i am only afraid that on the 31st of July it won’t work because the the V1 Authentication will be terminated.
        • C Offline
          C Offline
          calvin02
          I don’t know why but i have tried this method for other apps (e.g. BIMcollab, Revizto…) =]
          • Sini AaltoS Offline
            Sini AaltoS Offline
            Sini Aalto
            @JeroenKoomen yes it should be ok: we got in contact with Autodesk and the change of endpoints is indeed happening. They added us to the list of customers that get extra time until the 31st of July. The reason why we don’t need to make a hotfix release is that contrary to the earlier information we had, the required changes can only be done in the backend, which doesn’t require a new release. We have already implemented the changes in the backend but it may take some time until they become effective i.e. when V2 endpoints are in use. There should anyway be much enough time for that to happen before the end of month. So everything should be fine but we’ll follow up the situation in case problems would arise.
