  3. Calculation definitions (wall gross area)?
7 Posts 5 Posters 2.1k Views
  • Mats_KnutssonM Offline
    Mats_Knutsson
    wrote on last edited by Mats_Knutsson
    Where can I find calculation defintions? I started looking at walls and gross area. I use ArchiCAD and most often I have composite walls with several layers and I don’t get it what dimensions Solibri use for the wall area!?
    Br,
    Mats.
    Mats_KnutssonM 1 Reply Last reply
      Mats_Knutsson
      replied to Mats_Knutsson on last edited by
      BUMP…
        Hi. We don’t have specific definitions for these available, but they are calculated from the geometry of the components and the calculation algorithms can vary based on the type of the component.
        For the difference between gross area and normal, the algorithms are complicated but the difference should come from the possible holes in the walls. If there are no holes, the areas would be equal. The minimum versions come from the fact that the walls can be higher on some parts and the minimum values are calculated like the height was the minimum height in all parts of the wall. Most of the times walls are of constant height and thus the minimum versions of values are the same as the normal values.
        • XavierX Offline
          XavierX Offline
          Xavier
          Hi all,
          Are there any plans to add extra-calculations? for example:
          • In “Information Takeoff”, it will be really useful to add a “formulation column”.
          • In this “formulation column”, it should be possible to calculate, for example, a multiplication of two o more parameters.
          Best regards,
          Xavier Coll
          L 1 Reply Last reply
            b.huijskes
            If you sign up for Beta testing you are able to add those columns with basic JavaScript.
            @Eric has posted a quick summary on how to use JavaScript to do just that. You can view his post here: https://society.solibri.com/topic/246/javascript-api-documentation-alpha
              replied to Xavier on last edited by
              @Xavier like @b-huijskes said, the Javascript functionality might suit your needs.
              We would also like to hear if users were interested in fully programmable ITO API where you would write custom ITO columns with possible parametrization via the UI. It could be similar to the API which is used to write custom rules.
              • mpanceraM Offline
                mpanceraM Offline
                mpancera
                please do so!
                but first completely support IfcMaterialLayer and a easy understandable user interface for them / or give the users some nice help tutorial videos
                thanks
