  3. Merge IFC
Merge IFC
2 Posts 2 Posters 858 Views
  • petrinnnP Offline
    petrinnnP Offline
    petrinnn
    In the plumbing design, made in Revit, considering a vertical building, we have a lot of similar floors.
    In this case, what happening in Revit is: is create one file RVT, then we use LINKED MODEL RVT a lot of times.
    What’s the problem? When exporting IFC from Revit, if it’s a LINKED FILE, will be exported one by one.
    In a building with 30 floors, if all plumbing designs are made in this situation, we will have a lot of IFC FILES.
    Someone knows a way to MERGE all this IFC FILES?
    PS: i dont want to bind link in revit
    • JeroenKoomenJ Offline
      JeroenKoomen
      Hi @petrinnn,
      That is not possible in Solibri.
      Offcourse it can be done with other software tools, like SimpleBIM.
      Other workaround is to make a copy of your revit model, bind links in this copy and then export to IFC.
      Only use this copy with binded links to export to IFC.
      This is not really a question for this forum by the way 🙂
      Jeroen
