  4. Mathematical formulas
3 Posts 2 Posters 566 Views
  • R Offline
    R Offline
    Raphael
    I would like to know if is it possible to use mathematical formulas in Solibri ?
    Example, retrieve an angle from calculation with the parameters of height, width, length of the bounding rectangle.
    The purpose is to check if a pipe have the good inclination or not on stormwater system.
      Hi. This should be doable by writing a custom rule.
      You can check the API documentation from https://solibri.github.io/Developer-Platform/index.html
      It has a guide for writing rules and some examples on how to use the geometry of the components in the model for checking.
      As for the specific check you mention, the difficulty of making a check depends on how well the pipes have been modeled.
      • R Offline
        R Offline
        Raphael
        Ok.
        Thanks for your answer. 😊
        I will take a look at the API and take time to discover it.
        After I will try to develop a new rule.
        Have a nice day
        Raphaël
