Check if a beam is inside a wall (by: Relations)
Hi guys,
I am having some trouble with finding the right rule to check.
What I want:
I want to check if a wall contains a beam, founded by Relations.
All the walls that don’t have a beam should be alerted by Solibri.Why
Because I want to check if the supplier added a beam. After that, I can judge if it’s correct if there is or isn’t a beam inside the wall.
Used rules:
SOL/231/1.6What am I doing wrong?
Hopefully, one off the @Solibrians can help me out!
Thank you in advance,
@Nando Robbert shared the model via e-mail, sorry it took a while to get the answer here
This can be checked with at least these 2 rules:
rule #231
And
rule #232
@Robbert-Evers I can have a go if you have a model to share
rule #231
And
rule #232
