  4. Classification based on "GUID"
4 Posts 3 Posters 1.2k Views
  • Simo_ZS Offline
    Simo_ZS Offline
    Simo_Z
    Hello
    I am try to make a custom classification Rules base on the GUID elements but for some reason it doesn’t work.
    I got the Excel list with the GUID of the elements and relative Classification Name, I imported the data using the functionality Import Excel Worksheet but it doesn’t work. The format of the excel is correct, I started with an exported Excel from Classification Rules and the GUID of the elements are existing in the model.
    I don’t understand why it doesn’t work. Do you have any idea?
    Thanks
    Best Regards
    Simo
    RobinKramerR 1 Reply Last reply
    • RobinKramerR Offline
      RobinKramer
      replied to Simo_Z on last edited by RobinKramer
      @Simo_Z
      It’s because of the components filter. Now every element is excluded and nothing is included. That’s why the classification doesn’t see any components or GUID’s to work with.
      If you add an ‘include’ row, for example ‘Include Any’ or change one or the two rules to ‘Include’, hopefully it’s working correctly.
      Good luck!
      • Simo_ZS Offline
        Simo_ZS Offline
        Simo_Z
        Thanks Robin, you are right!
        Best Regards
        Simo
          can you please elaborate what you goal is with the GUIDs.
          From experience I know that there Codes are just machine readable and won’t always be there for the classification. If a new element gets created in your BIM authoring tool, it receives a new GUIDs which will be missing in your classification list in Solibri.
          Just was wondering how do you inted to implement it, and the benefits are 🙂
          TriPoint GmbH
          www.tri-point.at
