  4. Update model not updating component colors
13 Posts 8 Posters 3.9k Views
    wrote on last edited by JeroenKoomen
    @Solibrians
    I have this problem also… especially with models we use for communicating voids in a structual model…
    What sometimes helps: changing the color of the model using colormap. Firts unchecking “Use model colors” and then check “Use model colors” again. Below a model before and after that.
      But this solution does not work allways…
      Below a model which i updated in Solibri…
      If i open this one in Solibri in stead of updating the model I see this…
      @Solibrians any Idea how to fix this? It is really annoying because the colors are really important because the color represents the status of the void (new / approved / declined etc).
        @jeroenkoomen said in Update model not updating component colors:
        Removing the IFC model and adding again worked for me. However that’s not really the right solution…
          Yes that is not what you want because then you will loose all history of the elements in the old model in rulesets / presentations etc.
            @jeroenkoomen
            could we have these small colorful IFCs for testing?
              @matti-kannala said in Update model not updating component colors:
              @jeroenkoomen
              I am sending you IFC / SMC over the mail.
                @jeroenkoomen
                Thanks!
                • KevindenToomK Offline
                  KevindenToom
                  Is there already a solution for this problem?
                  we have the same problems with visability of the elements they were projected as transperecy but we want to see them as the normal colors.
                  Is there anyone who can help me with this issue.
                  A 1 Reply Last reply
                    Anees Alomar
                    replied to KevindenToom on last edited by
                    Hi @kevindentoom
                    Do you have an issue similar to this one?
                    https://society.solibri.com/topic/1553/how-could-the-aluminum-frames-of-the-windows-be-transparent/2?_=1634567239898
                      Patrick
                      I have the same issue.
                      Using “Remove Paint from Visible Objects” fixes the issue, even though I haven’t manually added the wrong colors to the .IFC:
