  4. Dimensions' color fills
9 Posts 5 Posters 2.7k Views
  • _c__ Offline
    _c__ Offline
    _c_
    is it possible to disable the new dimension fills?
    They are quite obstructive and hide too much: see blue label in the screenshot.
    c
      Try using the ‘auto-hide measurements’ functionality. It’s supposed to hide the measurements when you zoom out to a certain threshold, although you don’t have control when that happens…
      The settings also have a fill color settings, but there is no ability to choose transparant as a color. @Solibrians could that be a future change?
        replied to _c_ on last edited by
        @_c_ said in Dimensions' color fills:
        Not possible yet. The fill opacity is fixed to 205/255.
          @Ricardo said in Dimensions' color fills:
          Also the auto hide threshold distance is hard coded now to 10 times the measurement length and at least 2m.
          • 1m measurement will disappear when looking from 10m distance.
          • 1cm measurement will disappear when looking from 2m distance.
          • MattKnowlesM Offline
            MattKnowles
            I think this is beginning to frustrate a lot of people. Especially if we are using autorun. Measurements should be hidden by default then selected to reveal…not the other way around. I appreciate we can hide them but I always want to hide them, very minimal use case for having them on by default.
            This is like the 6th post ive seen about the measurements now since the update
            • _c__ Offline
              _c__ Offline
              _c_
              wrote on last edited by _c_
              Hiding the dimensions is not the right solution in many cases, for example when they are manually placed. I think the possibilty to disable fills or some gradient of transparency would be optimal.
              As a rule, the fill should also never cover the lines describing where the dimension is. This would unfortunately introduce some offset management.
              c
                replied to MattKnowles on last edited by
                @MattKnowlesWDC
                I agree, there is a lot of work to hide measurements, but also don’t forget the performance hit when Solibri tries to render a large amount of dimensions.
                There is a workaround to disable the measurements which I use. In the ‘Solibri.vmoptions’ under C:\Program Files\Solibri\SOLIBRI, add the following line of text:
                -DClashDetectionMatrix.NoClashVisualizations=true
                • BvanDalsumB Offline
                  BvanDalsumB Offline
                  BvanDalsum
                  in my opinion the new measurement tool is a pain in the *ss.
                  ik like the new features but when using Site or Anywhere there is really no control.
                  in that case i like the “old” measurement tool better. Not every improvement is progress.
                  • _c__ Offline
                    _c__ Offline
                    _c_
                    I beg to point to the fact that in this particular thread I do not wish to hide dimensions -I need them, but to hide their FILLS in order to make them show leading lines and geometry they currently cover. This was indeed better in the old tool.
                    c
