  3. Licensing issues
Licensing issues
52 Posts 8 Posters 9.7k Views
    Patrick
    And then it stopped again.
      LeifHagen
      Most of our users are on version 25.12.0.84, we have tried the steps as described without success. We get the same error message as Patrick. For me it happens every time, other users sometimes get a license. All our users are on standard online license. Have already shared logfiles with support.
        LeifHagen
        wrote on last edited by LeifHagen
        Any updates regarding this issue? @Solibrians
          Patrick
          Still here. Was mostly gone Friday, but appeared again today.
          • fmohusF Offline
            fmohusF Offline
            fmohus
            wrote on last edited by fmohus
            Same error message here - Solibri Office 26.4.1.108. Persistent error, have tried uninstall and reinstall, same problem. Runtime log attached.
            image.pngruntime.log
              wrote on last edited by Matti
              Could you test that you are able to load following certs:
              https://api.solibri.com/cert
              should give a page: MIIHBjCCBO6gAwIBAgIQD8dHLMPmUhK…
              http://cacerts.digicert.com/GandiCert.crt (copy url to browser)
              should download a crt file size around 2KB
              • fmohusF Offline
                fmohusF Offline
                fmohus
                The first one returns a result as you indicate: MIIHBjCCBO6gAwIBAgIQD8dHLMPmUhKWlpzoDn25RDANBgkqhkiG9w0BAQsFA… etc…
                The second one doesn’t return anything - just gives a timeout.
                  Try copy the second URL to browser
                  L 2 Replies Last reply
                  • fmohusF Offline
                    fmohusF Offline
                    fmohus
                    Yep, 2kB file.
                    • SigneLaksaaS Offline
                      SigneLaksaa
                      @Matti - How’s it going with the investigation? We have a lot of people both in COWI and Multiconsult struggeling to open Solibri Office.
                        replied to SigneLaksaa on last edited by
                        #18
                        @SigneLaksaa said in Licensing issues:
                        We are investigating as we speak. Currently this seems to be very focused in Norway. We’ll report back here as soon as we have more information to share.
                          Is there anyone here currently who would be able to connect with us in a call to help investigate directly while logging in?
                          SigneLaksaaS L 2 Replies Last reply
                            SigneLaksaa
                            @tonigyllenberg you can call [email protected]
                              LeifHagen
                              #21
                              @tonigyllenberg you can contact me: [email protected] or +4797561599
                                LeifHagen
                                #22
                                  LeifHagen
                                  #23
                                  @Matti First one gives me something like this: MIIHBjCCBO6gAwIBAgIQD8dHLMPmUhKWlpzoDn25RDANBgkqhkiG9w0BAQsFADA1MQswC
                                    Hello all,
                                    As an update on this, investigations on the matter until now have shown that:
                                    • For some users the connection to cacerts.digicert.com is blocked.
                                    • Allowing outbound HTTP/80 to cacerts.digicert.com should fix the problem.
                                    • Connection can be tested by Windows PowerShell command:
                                      Test-NetConnection cacerts.digicert.com -Port 80
                                    We still do not have information on why the connection is all of a sudden blocked for many Norwegian customers. We are continuing to investigate with our certificate provider and will keep you informed as soon as we have more information to share. We apologize for the inconvenience.
                                    • fmohusF Offline
                                      fmohusF Offline
                                      fmohus
                                      #25
                                      Windows PowerShell command: Test-NetConnection cacerts.digicert.com -Port 80 returned TcpTestSucceeded : True. …But the problem remains unfortunately…
                                        @fmohus
                                        Because the Test-NetConnection succeeded,
                                        Try delete .solibri folder in your home directory and start Solibri again
                                        Try adding this line to “C:\Program Files\Solibri\SOLIBRI-26.4.1\Solibri.vmoptions”
                                        P fmohusF 2 Replies Last reply
                                          Patrick
                                          replied to Matti on last edited by Patrick
                                          #27
                                          @Matti Worked for me, once, then it suddenly stopped working again.
