  3. Issues loose connection when updating model
20 Posts 5 Posters 4.7k Views
    If component type changes from Flow Segment to Duct or Column to Beam the results are lost in rechecking even the IFC Guid stays the same. This has been always the case in Solibri. Note: also this effects on many filters in rules, classifications and ITOs. The new component type might not be included in the existing filters. The results might change or be missing also due to this.
    In IFC2x3 there is no IFCDUCT entity like there is in IFC4. The component type (e.g. Duct) is selected based on the IFCTYPE entity (e.g. IFCDUCTSEGMENTTYPE).
    I believe that there is two possible cause for the problem that you encountered:
    1. The IFCDUCTSEGMENTTYPE is added the IFC file
    2. Solibri has been fixing issues in the IFC type import and in the earlier version the IFCDUCTSEGMENTTYPE was not imported correctly. Now the new version brings the type in and the component changes to Duct from IfcFlowSegment.
    We will check if the results could be some how preserved in case of change in component type.
    JMannJ 1 Reply Last reply
    • JMannJ Offline
      JMannJ Offline
      JMann
      wrote on last edited by JMann
      And now the you mention it @tonigyllenberg, sometimes issues are deleted from the presentation after synchronization, saving, closing and re-opening the smc-file.
      That means the issues are synched to e.g. BIMcollab but can’t be found in the presentation in Solibri anymore. In the checking layout the issues are still there – but marked with the symbol that it hasn’t been added to a presentation yet:
      I can’t create this problem on purpose but will keep you updated when this happens again.
      COMPENDIUM BIM + Kybernetik
      • JMannJ Offline
        JMannJ Offline
        JMann
        @Matti-Kannala said in Issues loose connection when updating model:
        Isn’t it a big difference whether a component is changed from column to beam – I understand that case – and additional type information to one component in the updated model? IfcFlowSegment still is an IfcFlowSegment, The type alone shouldn’t affect the issue management when the entity and GUID stay the same. And the IfcName shouldn’t affect the issues also.
        Example:
        In a bigger office project the architects re-named walls for better connection to the cost management. This went terribly wrong. Some walls lost the information in IfcName and got the value “LEER” (=empty). That affected different kinds of walls e.g. inner and outer, walls with and without insulation. So the categorization changed, summed up the walls with the name “LEER” in one file of the tree and all issues concerning these walls were lost.
          A bit offtopic, but a tip for anybody who wants to run older Solibri versions to test things out; enable Hyper-V on Windows. This allows you to install a virtual machine on your computer, where then an older version of Solibri can be installed. So this eliminates the need to remove existing Solibri installations,
          https://docs.microsoft.com/nl-nl/virtualization/hyper-v-on-windows/quick-start/enable-hyper-v
            Also in my opinion this fault happens for some reason with the loss of either the IFC Entity, IFC Type or even both. It clearly visible at @JMann screenshots, in the first one you see the IfcFlowSegment and on the second (updated model) there is no IFC Entity for the same element. In both cases GUID is the same.
            I have tested also my models and came to the same conclusion. In my case the proxy element is an IfcBuildingElementProxy when I did the first check, respectively issue slide. In the next model update, the IFC Entity is missing, and also the Issue connectivity to those elements is gone.
              Thank you for the additional information. We will discuss this internally to see if there is a way that results could somehow preserved in case the component type changes. And of course, if you have models which can be shared for testing and development, they are always welcome and much appreciated!
              • JMannJ Offline
                JMannJ Offline
                JMann
                Thank you @tonigyllenberg!
                • JMannJ Offline
                  JMannJ Offline
                  JMann
                  Hey @tonigyllenberg,
                  is there an update or workaround for this topic?
                  Thank you!
                    Hello @JMann,
                    My apologies for the delay! The matter was discussed internally, and we have an issue created for implementation. The issue has currently not been selected for development, however we are planning on making improvements to checking features in the near future, and at the same time we will open the issue up again.
                    • JMannJ Offline
                      JMannJ Offline
                      JMann
                      Thank you @tonigyllenberg for your reply! Can’t wait for the progress!
                      • JMannJ Offline
                        JMannJ Offline
                        JMann
                        do you have an update on this topic?
                          Hello @JMann,
                          Although the issue has been looked into before, it has not yet been selected for development. This issue falls under Checking improvements, which we have an extensive list of. Once we begin working more on checking related items, we will revisit this topic.
                          • JMannJ Offline
                            JMannJ Offline
                            JMann
                            are there any updates on this issue? Thanks in advance!
                              Hello @JMann,
                              Unfortunately we don’t have any updates on the topic yet. At the moment we are currently not working on checking improvements, and this item has not been selected for development.
