  4. How do I update Rules in RuleSets
17 Posts 8 Posters 5.6k Views
  • _c__ Offline
    _c__ Offline
    _c_
    I’d like to refresh this thread.
    Is there a trick to re-load a rule from the resource path or do we REALLY need to edit every file wherever the obsolete once have issues?
    c
      @_c_ said in How do I update Rules in RuleSets:
      I am afraid that you have to reload the ruleset manually in each file where you want to “update”.
      • _c__ Offline
        _c__ Offline
        _c_
        But we are loosing the links to the issues when doing that. How do you do it, so that it doesn’t happen?
        c
          Hi. Check also an upcoming version where rulesets can be externalized to a common location (https://society.solibri.com/topic/1194/upcoming-solibri-version-testers-wanted/17).
          If there you update the ruleset, say, on a network drive or a OneDrive folder, all projects that refer to it, automatically always load the newest version.
          T _c__ 2 Replies Last reply
            TheoR
            @lasse-lindqvist will this also apply to Classifications and Information Takeoffs?
              replied to TheoR on last edited by lasse.lindqvist
              @theor said in How do I update Rules in RuleSets:
              Yes, both are externalizable in the same way. Externalizing them is of course optional and the old way of handling them can still be used if wished.
              • _c__ Offline
                _c__ Offline
                _c_
                @lasse-lindqvist thank you.
                We are going nuts with paths in Solibri. May I also hope that we’ll have relative paths now?
                c
                  replied to _c_ on last edited by
                  @_c_
                  In which use case scenarios? What I am most afraid of is the fear of breaking rules, ITOs, … because classification names have been modified. Will this finally going to be fixed?
                  • _c__ Offline
                    _c__ Offline
                    _c_
                    I did an extensive list of observations a while ago, here. I made exact lists towards the end of the thread.
                    Some I saw as solved. I discovered, later, that on Mac the Application is always overridden, this is certainly a bug.
                    Then that there is an ini file where paths are stored, that helps.
                    Etc.
                    c
                    • I Offline
                      I Offline
                      ILikeAnArch
                      I have one question regards rulesets.
                      The scenario:
                      1. I use ruleset manager to create the XXX Ruleset and save to C Drive
                      2. I add to the project Checking
                      3. I run the XXX Ruleset
                      4. I now want to add some additional Rules from the Library to the original XXX Ruleset
                      5. I now override the XXX Ruleset on the C Drive through Ruleset Manager
                      6. I can load the revised XXX Ruleset into the project….
                      But, the additional rules don’t come over. I am still with the original rules only.
                      As mentioned above, the only solution I can find is to delete and load the ruleset again, loosing the previous issues.
                      Am I missing something?
                        I’m reviving this old post of mine from five years ago, because I’m facing a similar situation on a current project.
                        I have three different SMC files that each include two rulesets (csets). One of them is the QualityGate Check, which should be identical across all three files. I’ve noticed that when I modify this ruleset and save it, the changes do not propagate to the other SMC files. The ruleset is also assigned via role. The only workaround that currently works for me is to delete the ruleset in each file and re-import it, but that causes me to lose all existing checking results.
                        Has there been any progress on this in the last five years? Is there an efficient way to synchronize rulesets across multiple files without losing results?
                        • _c__ Offline
                          _c__ Offline
                          _c_
                          Yes please, resolve this problem.
                          c
