  3. Solibri office won't start - (Java) Error during startup
28 Posts 17 Posters 9.0k Views
  • MarioM Offline
    MarioM Offline
    Mario
    We have the same Problem. Ist there a solution?
      Ronald van Emst
      same here!
      can’t open solibri at all.
        b.huijskes
        We have the same issue.
          We are sorry for any inconvenience this may have caused. Solibri is fixing the problem at the moment.
            LeifHagen
            Can you please inform us here as soon as the problem is fixed?
              Same here, pretty bad timing …
              • HechtwieFischH Offline
                HechtwieFisch
                Jep we have the same problem -
                good to know solibri is fixing it right now!
                @Solibrians do you maybe have a approximately
                estimate how long it will take ?
                • MaxCallaghanM Offline
                  MaxCallaghan
                  Same here, happened to one of our other regions last month. Got IT checking to ensure our systems aren’t blocking the required ports. If it’s an issue on Solibri’s side, hopefully it can be resolved promptly.
                    Hello all!
                    Please see the message below for more information.
                    Unscheduled maintenance break
                    We are currently doing some unscheduled maintenance that is affecting both Solibri Solution Center and using Solibri software. We have identified the possible issue and are working our hardest to resolve the situation as soon as possible.
                    We would highly appreciate, if you could please forward this information to the Solibri users in your organization.
                    We will update you immediately when the functionality is restored.
                    We apologize for any inconvenience caused.
                    Best regards,
                    Team Solibri
                    5
                      @tonigyllenberg said in Solibri office won't start - (Java) Error during startup:
                      Hello all!
                      Best regards,
                      Team Solibri
                      FYI, this is the message that I now receive:
                        R.H.J
                        This is the one that I get. I guess they’re related since Solibri Office was working fine a few hours ago.
                          joukol
                          I’m getting an error while installing the latest update, does it have to do with the same issue?
                          I tried both updating and a clean install and neither worked.
                            Up and running again?
                            K 1 Reply Last reply
                              KarlF
                              @jsn office is up and running for me now. Have a go now.
                              • M GroenewoudM Offline
                                M Groenewoud
                                Looks like there is a solution, Solibri is working again at our office
                                  HechtwieFisch
                                  yes works again here too! Thank you for fixing it Solibri!
                                    Can confirm, it works again.
                                      Hello all!
                                      After the downtime event this morning, we are recovering slowly back to normal, and users are able to access both SSC and Solibri. Users might however get denials until the service health has been completely recovered. Please see this post on our website for more information on the case:
                                      https://www.solibri.com/ssc-maintenance
                                        @tonigyllenberg @Solibrians
                                        We are having this issue again today, same error. We can’t use our office licences.
                                        I hope that you can resolve this quickly…
                                          Seba
                                          Same here at our office.
