  3. Solibri office won't start - (Java) Error during startup
28 Posts 17 Posters 12.6k Views
    b.huijskes
    We have the same issue.
      We are sorry for any inconvenience this may have caused. Solibri is fixing the problem at the moment.
        LeifHagen
        Can you please inform us here as soon as the problem is fixed?
          Same here, pretty bad timing …
          • HechtwieFischH Offline
            HechtwieFisch
            Jep we have the same problem -
            good to know solibri is fixing it right now!
            @Solibrians do you maybe have a approximately
            estimate how long it will take ?
            • MaxCallaghanM Offline
              MaxCallaghan
              Same here, happened to one of our other regions last month. Got IT checking to ensure our systems aren’t blocking the required ports. If it’s an issue on Solibri’s side, hopefully it can be resolved promptly.
                Hello all!
                Please see the message below for more information.
                Unscheduled maintenance break
                We are currently doing some unscheduled maintenance that is affecting both Solibri Solution Center and using Solibri software. We have identified the possible issue and are working our hardest to resolve the situation as soon as possible.
                We would highly appreciate, if you could please forward this information to the Solibri users in your organization.
                We will update you immediately when the functionality is restored.
                We apologize for any inconvenience caused.
                Best regards,
                Team Solibri
                5
                  @tonigyllenberg said in Solibri office won't start - (Java) Error during startup:
                  Hello all!
                  Best regards,
                  Team Solibri
                  FYI, this is the message that I now receive:
                    R.H.J
                    This is the one that I get. I guess they’re related since Solibri Office was working fine a few hours ago.
                      joukol
                      I’m getting an error while installing the latest update, does it have to do with the same issue?
                      I tried both updating and a clean install and neither worked.
                        Up and running again?
                        K 1 Reply Last reply
                          KarlF
                          @jsn office is up and running for me now. Have a go now.
                          • M GroenewoudM Offline
                            M Groenewoud
                            Looks like there is a solution, Solibri is working again at our office
                              HechtwieFisch
                              yes works again here too! Thank you for fixing it Solibri!
                                Can confirm, it works again.
                                  Hello all!
                                  After the downtime event this morning, we are recovering slowly back to normal, and users are able to access both SSC and Solibri. Users might however get denials until the service health has been completely recovered. Please see this post on our website for more information on the case:
                                  https://www.solibri.com/ssc-maintenance
                                    @tonigyllenberg @Solibrians
                                    We are having this issue again today, same error. We can’t use our office licences.
                                    I hope that you can resolve this quickly…
                                      Seba
                                      Same here at our office.
                                        Ronald van Emst
                                        Same here.
                                        • david.weltsD Offline
                                          david.welts
                                          wrote on last edited by david.welts
                                          #23
                                          Hello all,
                                          We are currently facing an issue with Certificates which prevents Solibri from launching successfully.
                                          We are aware of the situation and currently working to fix it on our side and resolve the issue ASAP.
                                          We will give an update once the issue is resolved.
                                          3
