  3. ITOs and Autorun
ITOs and Autorun
18 Posts 5 Posters 4.0k Views
  • I Offline
    I Offline
    IFC GHOST
    Hello solibrians,
    Is there any news on generating ITOs using Autorun.
    Regards,
      BIM1337
      My company is also very interested in this!
      • john.lippJ Offline
        john.lippJ Offline
        john.lipp
        Hi @IFC-GHOST
        It’s on the list of release notes for the version 9.12.8 Beta:
        Solibri 9.12.8 Beta round open
        Autorun
        • Added support for creation of model category
        • Added support for BCF version 2.1
        • Added support for automatic update
        • Added support for running ITOs and exporting to Excel
          openito
          • Opens the specified ITO file.
          • Parameters:
            • file: Specify the path to the ITO file. The file type must be .ito.
          • Example: <openito file="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Spaces.ito" />
          takeoff
          • Calculates the ITOs with matching name if specified or calculates all ITOs if no name is specified.
          • Example: <takeoff />
          • Optional Parameter:
            • name: Specify the ITO name.
          • Example: <takeoff name="Spaces" />
          itoreport
          • Creates a report of ITO results from Information takeoff view.
          • Report can be created using an excel template or it can be a plain excel report.
          Plain Excel Report
          • If a specific ITO name is provided, then report is created for it. Else, it reports all ITOs.
          • Parameters:
            • file: Specify the path and the name for the report file. The file format must be .xls or .xlsx.
          • Optional Parameters:
          • Example: <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" />
          • Example: <itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" />
          Excel Template Report
          • The report is created using the excel template.
          • The report file and template file must have same excel format, either .xls or .xlsx.
          • Parameters:
            • templatefile: Specify the path and the file name for the template to be used when creating the report.
          • reportTitle: Add a name for the report.
          • Example: <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Spaces.xlsx" />
          • Example: <itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Building Element Quantities.xlsx" />
          • Example: <itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Building Element Quantities.xlsx" />
          B 1 Reply Last reply
            BIM1337
            @matti-kannala
            “or calculates all ITOs if no name is specified.”
            So without specifying a name it’ll takeoff all ito’s in the smc file? That’s great!
            • I Offline
              I Offline
              IFC GHOST
              This just amazing, useful and optimal, thanks for this magic update.
              Does this work for all the Solibri versions ?
              Regards,
                replied to IFC GHOST on last edited by Matti
                @ifc-ghost
                Only 9.12.8 onwards.
                There are also some other autorun improvements:
                Fix BCF 2.1 autorun reporting
                • Example: <bcfreport file="C:\SolibriAutorun\reports\SolibriBuilding_BCFReport.bcf" version="2.1"/>
                Setting model categories
                <openmodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\Solibri Building.ifc">
                <category>CAT_NAME1</category>
                <category>CAT_NAME2</category>
                </openmodel>
                updatemodel
                • Updates a specific IFC file included in the SMC model with a new IFC file.
                • Parameters:
                  • file: Specify the file and the path to the file to be updated. The file must be included in the SMC model opened by the openmodel task.
                • Optional parameters:
                  • with: Specify the path to the new version of the file.
                  • autoupdate: When true, model is updated only when the IFC file is newer than the previously imported version. When false, the model is updated unconditionally.
                • Example: <updatemodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\SMC Building.ifc" autoupdate="true"/>
                autoupdatemodels
                <autoupdatemodels/>
                • Updates all imported models that have a newer version on the disk.
                • I Offline
                  I Offline
                  IFC GHOST
                  This is just amazing, thank you for these improvements.
                    BIMGOAT
                    Has anybody tried Excel Template Report, it’s not working for me. It crashes.
                      replied to BIMGOAT on last edited by
                      @bimgoat
                      Could you check the log files. There is also separate autorun.log.
                      Check the paths.
                      You also try this one:
                      <?xml version="1.0" encoding="ISO-8859-1"?>
                      <batch name="Simple Batch" default="root">
                      <!-- This is the starting task -->
                      <target name="root">
                      <openmodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\Solibri Building.ifc" />
                      <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces Simple.xlsx" />
                      <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces with Template.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Spaces.xlsx" />
                      <exit />
                      </target>
                      </batch>
                        As result of previous autorun you will get:
                          Solibri 9.12.8 Developer Platform documentation is published.
                          It includes the new autorun features.
                          https://solibri.github.io/Developer-Platform/
                            BIMGOAT
                            wrote on last edited by BIMGOAT
                            @matti-kannala
                            I use a custom made template that works perfectly when using it in Solibri, to generate the report from template.
                            I’ll try the example you’re suggesting but there’s an error at the moment when starting Solibri Office.
                            This is from the autorun log file when it crashes on the last task that’s the ito template report.
                            2021-12-16 17:00:40.800+0100 ERROR c.s.s.p.b.actions.BatchAction - Failed while running BatchRun
                            java.lang.NullPointerException: Cannot invoke "com.solibri.resource.Resource.getString()" because the return value of "com.solibri.saf.core.resource.RecentResource.getResource()" is null
                            	at com.solibri.saf.core.resource.RecentResource.c(Unknown Source)
                            	at com.solibri.saf.core.resource.RecentResource.a(Unknown Source)
                            	at com.solibri.saf.core.resource.RecentResource.addRecentResources(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.a(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.b(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.run(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.BatchTarget.run(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.BatchRun.runTarget(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.BatchRun.run(Unknown Source)
                            	at com.solibri.saf.plugins.batchplugin.actions.BatchAction.runBatch(Unknown Source)
                            	at com.solibri.modelchecker.core.ModelChecker.a(Unknown Source)
                            	at java.base/java.lang.Thread.run(Thread.java:831)
                              BIMGOAT
                              Is it required to have an ITO in the SMC file with the exact same content as the report template?
                              When using the report template in Solibri this is not a requirement, put perhaps using Autorun it is required?
                                BIM1337
                                replied to Matti on last edited by BIM1337
                                @matti-kannala said in ITOs and Autorun:
                                @bimgoat
                                Check the paths.
                                <exit />
                                </target>
                                </batch>
                                Same for me, the one you suggest to try works great.
                                Yet I get the same error when using a template that we use to extract model timestamps.
                                This is the content of the template, works when reporting ito in Solibri, with Autorun it crashes.
                                  BIM1337
                                  It works for me now after adding this line:
                                  <openito file="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Modellist.ito" />
                                  <takeoff name="Modellist" />
                                  No more crash!
                                  MattiM 2 Replies Last reply
                                    replied to BIM1337 on last edited by
                                    @bim1337
                                    There is a problem with ITO template reports that happens with some .ito files.
                                    There is a workaround for the problem:
                                    1. Open the ITO
                                    2. Report once with any template
                                    3. Save ITO
                                    This will be fixed to next release.
                                      #18
                                      @bim1337
                                      Solibri 9.12.8.33 (hotfix for 9.12.8.29) released yesterday.
                                      It contains fix for Autorun ITO Template Report issue.
