ITOs and Autorun
openito
Opens the specified ITO file.
Parameters:
- file: Specify the path to the ITO file. The file type must be .ito.
Example:
<openito file="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Spaces.ito" />
takeoff
Calculates the ITOs with matching name if specified or calculates all ITOs if no name is specified.
Example:
<takeoff /> -
Optional Parameter:
- name: Specify the ITO name.
Example:
<takeoff name="Spaces" />
itoreport
Creates a report of ITO results from Information takeoff view.
Report can be created using an excel template or it can be a plain excel report.
Plain Excel Report
If a specific ITO name is provided, then report is created for it. Else, it reports all ITOs.
Parameters:
- file: Specify the path and the name for the report file. The file format must be .xls or .xlsx.
Optional Parameters:
Example:
<itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" /> -
Example:
<itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" />
Excel Template Report
The report is created using the excel template.
The report file and template file must have same excel format, either .xls or .xlsx.
Parameters:
templatefile: Specify the path and the file name for the template to be used when creating the report.
reportTitle: Add a name for the report.
Example:
<itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Spaces.xlsx" /> -
Example:
<itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Building Element Quantities.xlsx" /> -
Example:
<itoreport file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces.xlsx" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Building Element Quantities.xlsx" />
Only 9.12.8 onwards.
There are also some other autorun improvements:
Fix BCF 2.1 autorun reporting
- Example:
<bcfreport file="C:\SolibriAutorun\reports\SolibriBuilding_BCFReport.bcf" version="2.1"/>
Setting model categories
<openmodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\Solibri Building.ifc"> <category>CAT_NAME1</category> <category>CAT_NAME2</category> </openmodel>updatemodel
Updates a specific IFC file included in the SMC model with a new IFC file.
Parameters:
- file: Specify the file and the path to the file to be updated. The file must be included in the SMC model opened by the openmodel task.
Optional parameters:
with: Specify the path to the new version of the file.
autoupdate: When true, model is updated only when the IFC file is newer than the previously imported version. When false, the model is updated unconditionally.
Example:
<updatemodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\SMC Building.ifc" autoupdate="true"/>
autoupdatemodels
<autoupdatemodels/>- Updates all imported models that have a newer version on the disk.
- Example:
Could you check the log files. There is also separate autorun.log.
Check the paths.
You also try this one:
<?xml version="1.0" encoding="ISO-8859-1"?> <batch name="Simple Batch" default="root"> <!-- This is the starting task --> <target name="root"> <openmodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\Solibri Building.ifc" /> <openito file="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Spaces.ito" /> <takeoff name="Spaces" /> <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces Simple.xlsx" /> <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces with Template.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Spaces.xlsx" /> <exit /> </target> </batch> -
As result of previous autorun you will get:
Solibri 9.12.8 Developer Platform documentation is published.
It includes the new autorun features.
https://solibri.github.io/Developer-Platform/ -
@matti-kannala
I use a custom made template that works perfectly when using it in Solibri, to generate the report from template.
I’ll try the example you’re suggesting but there’s an error at the moment when starting Solibri Office.
This is from the autorun log file when it crashes on the last task that’s the ito template report.
2021-12-16 17:00:40.800+0100 ERROR c.s.s.p.b.actions.BatchAction - Failed while running BatchRun java.lang.NullPointerException: Cannot invoke "com.solibri.resource.Resource.getString()" because the return value of "com.solibri.saf.core.resource.RecentResource.getResource()" is null at com.solibri.saf.core.resource.RecentResource.c(Unknown Source) at com.solibri.saf.core.resource.RecentResource.a(Unknown Source) at com.solibri.saf.core.resource.RecentResource.addRecentResources(Unknown Source) at com.solibri.saf.core.resource.RecentResource.addRecentResources(Unknown Source) at com.solibri.saf.core.resource.RecentResource.addRecentResources(Unknown Source) at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.a(Unknown Source) at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.b(Unknown Source) at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.b(Unknown Source) at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.a(Unknown Source) at com.solibri.saf.plugins.batchplugin.tasks.ReportItoTask.run(Unknown Source) at com.solibri.saf.plugins.batchplugin.BatchTarget.run(Unknown Source) at com.solibri.saf.plugins.batchplugin.BatchRun.runTarget(Unknown Source) at com.solibri.saf.plugins.batchplugin.BatchRun.run(Unknown Source) at com.solibri.saf.plugins.batchplugin.actions.BatchAction.runBatch(Unknown Source) at com.solibri.modelchecker.core.ModelChecker.a(Unknown Source) at java.base/java.lang.Thread.run(Thread.java:831) -
@matti-kannala said in ITOs and Autorun:
Check the paths.
<?xml version="1.0" encoding="ISO-8859-1"?> <batch name="Simple Batch" default="root"> <!-- This is the starting task --> <target name="root"> <openmodel file="C:\Users\Public\Solibri\SOLIBRI\Samples\ifc\Solibri Building.ifc" /> <openito file="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Spaces.ito" /> <takeoff name="Spaces" /> <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces Simple.xlsx" /> <itoreport name="Spaces" file="C:\Users\Public\Solibri\SOLIBRI\Samples\Spaces with Template.xlsx" reportTitle="Report" templatefile="C:\Users\Public\Solibri\SOLIBRI\Information Takeoff\Templates\Spaces.xlsx" /> <exit /> </target> </batch>Same for me, the one you suggest to try works great.
Yet I get the same error when using a template that we use to extract model timestamps.
This is the content of the template, works when reporting ito in Solibri, with Autorun it crashes.
M Matti marked this topic as a question on
M Matti has marked this topic as solved on
