BCF Live Connector | Cannot filter
Re: Solibri 9.12.8 has been released!
Hi there,
I can’t use the filter option on BCF Live Connector with Bimsync projects.
It works with BIMcollab though.
Best regards,
At the launch Solibri 9.12.8.29 had problem with filtering with Bimsync (and other BCF 3 based servers like Aconex)
In few days Bimsync made a workaround on server side.
Later Solibri made hotfix 9.12.8.33 that fixed the problem in Solibri side also.BCF filter should work in 9.12.8.33 with all servers.
Could you tell which data you used for filtering?
The problem might be related some specific fields or data. -
Hi @twosk , would you be able to send the log folder (after zipping it) to [email protected]? You can find the log folder from the path: C:\Program Files\Solibri\SOLIBRI.
Also, along with the log folder, please send us the filter map (.blcfilter) file. You can find the filter map file from the path: C:\Users\USERNAME\AppData\Roaming\Solibri\filtermap
@Solibrians
Any updates on this matter? -
If I remember correct, this is a Trimble Connect issue. They need to implement the filtering.
@Pasi-Paasiala
Is this missing from API? Because Trimble Connect Web has it.
More info https://docs.browser.connect.trimble.com/bcf-topics/topics-listing -
@lraimo Trimble connect does not have this implemented in their implementation of BCF-API.
I have communicated this to Trimble.
@Solibrians Have you also communicated this to Trimble? Filtering is very important when project is big with hundreds or thousands of issues -
I’ve communicated this to Trimble as well via their support ticket service or such.
Edit: Corrected grammar.
I think this is not CDE , but solibri’s problem
1.At the moment filter works, but sometimes I can not import all selected issues, i need to mark it.
2.Imported slides contain wrong section and model selection. Exported views are correct in the CDE (dalux).
3.I have tried both dark and light UI and somewhat outcome regarding BCF live connector is different.
