  3. Windows 11 and Solibri
8 Posts 5 Posters 2.9k Views
  • tonigyllenbergT Online
    Dear Society members,
    Regarding Windows 11 support for Solibri, at the moment we are in the middle of testing and investigating potential issues which might come about. For the time being, Windows 11 is not officially supported, meaning that you may or may not encounter issues running Solibri on Windows 11 machines.
    Common known problems:
    • Solibri does not recognize Windows 11 under system information (displays 10)
    • Intermittent freezes or crashes
    Workarounds
    In case you have updated to Windows 11 and are running into problems, one potential workaround is to run Solibri in compatibility mode for Windows 8:
    If you do encounter issues Windows 11, we ask that you please report them by sending a support email with all relevant information to [email protected]
    • EricE Eric marked this topic as a regular topic on
      @tonigyllenberg
      Is there a place where we can see what already known issues are?
      • gvbeersG Offline
        gvbeersG Offline
        gvbeers
        Hi @tonigyllenberg
        Just like @Ricardo set, there is a place where we collect knowledge problems?
        Over here we run into many crashes and freezes. I will let you know that running in compatibility mode increases stability.
        Running:
        • OS: Microsoft Windows 11 Enterprise
        • Version: 10.0.22000 N/A Build 22000
        • Solibri version: 9.12.8.33
        Greetings
        G. van Beers
        Project coördinator BIM
        LinkedIn: https://www.linkedin.com/in/gvanbeers/
          Hello all!
          As we don’t have a place currently for common known issues, we could begin to collect them in this thread. I’ll update the original post with known issues on a regular basis.
            @tonigyllenberg said in Windows 11 and Solibri:
            Hello all!
            Toni, We have a few collegues on windows 11 now, but one has had a few crashes in the last few days. He mentioned that he thinks it happened the most when he was making dimensions. (I changed it now to compability mode)
            I will email the support team the error and runtime logfiles.
              @Solibrians ,
              Any update about when Windows 11 will be supported?
              • RicardoR Ricardo referenced this topic on
              • Maxime SabbaghM Offline
                Maxime Sabbagh
                Hello, Is there any update about the the compatibility between solibri and windows 11 ?
                Thank you
                https://www.parallel.digital/
                david.weltsD 1 Reply Last reply
                • david.weltsD Offline
                  david.welts
                  replied to Maxime Sabbagh on last edited by david.welts
                  Hi all,
                  Regarding Windows 11, we can confirm that Solibri is compatible and there shouldn’t be a reason to avoid using it. Previous issue should be fixed already in 9.13.0 . We will update this page to reflect the information: https://help.solibri.com/hc/en-us/articles/1500005246041-System-Requirements
                  However, if you are experiencing any issues, please contact our support and we will make sure the issues are logged and fixed.
