  3. Special symbols in classification does not show up
12 Posts 4 Posters 2.4k Views
    twosk
    Hi, I have structural model with assemblies that have special symbols in name.cd7ce53f-7fa5-4039-9242-cd250229bd23-image.png
    In solibri newest version it does not show up
    I believe it was fine in previous versions.
    Is it something i can fix myself?
    • bariscanpolatB Offline
      bariscanpolat
      With the update, special characters are not shown right, not only classification:
      And you are right, it was ok before.
        twosk
        wrote on last edited by twosk
        @bariscanpolat
        Perhaps its connected to regional settings? Or is it ok in you computer?
        M 1 Reply Last reply
          bariscanpolat
          I don’t know if it is about regional settings, because before the update it was ok
            replied to bariscanpolat on last edited by
            @twosk @bariscanpolat
            Could you confirm which version of Solibri you are using and are they correct in some older Solibri version?
              replied to Matti on last edited by Matti
              Also you can try these settings
              or
                manuel.furia Solibrians
                replied to twosk on last edited by manuel.furia
                @twosk
                It is most likely connected to regional settings. Before 9.13.4, Solibri used the System default encoding for reading strings in ifc files. This was now changed to UTF-8 by default, which can be changed from the Solibri settings (but the system settings are ignored).
                You can try this:
                You should probably try Windows-1257 (Baltic).
                T 1 Reply Last reply
                  @Matti-Kannala Windows-1252 is not going to work, since it does not have the U with the bar on top. Windows-1257 may be the right encoding.
                    bariscanpolat
                    @Matti-Kannala thank you, I changed the settings to UTF-8 and it worked for me
                      twosk
                      replied to manuel.furia on last edited by
                      @manuel-furia
                      it does not work with the newest version.
                      With an older version it works if I reupdate the file.
                      It works with the newest version and UTF-8 settings.
                      Thank you for your suggestion.
                        So, I’m guessing the strings in the file are encoded with UTF-8, but the IFC Import Setting uses the system’s encoding by default, not UTF-8 as I was expecting.
                        Since UTF-8 strings are much more common than other encodings, I will create a ticket to always default to UTF-8 instead of System’s default settings.
                          Solibri 9.13.5 has been released!
                          IFC import handles now special characters correctly.
                          UTF-8 is now the default encoding for IFC.
                          https://society.solibri.com/topic/2524/solibri-9-13-5-has-been-released
                          • MattiM Matti locked this topic on
