  4. IFC exported from TEKLA displays the Profile Height and Width reversed.
3 Posts 2 Posters 707 Views
    tomoki
    Hi @Solibrians
    When exporting beams from TEKLA, the Profile Height and Profile Width are reversed in the quantity tab. ARCHICAD and REVIT do not have this problem.
    Is this a bug or is it an original specification?
    When I use our custom rules to check if the sectional shape are consistent, I am having trouble checking only the IFC exported from TEKLA.
    IFC file is also attached for confirmation.
    Girder_TEKLA.ifc
    Girder_REVIT.ifc
      Hi. Based on the IFC contents it seems that the data is swapped there already?
      Tekla:
      #42= IFCRECTANGLEPROFILEDEF(.AREA.,‘\X2\0043004F004E25A1003600350030002A003300350030\X0’,#41,350.,650.);
      Revit:
      #138= IFCRECTANGLEPROFILEDEF(.AREA.,‘1GA1’,#137,650.,350.000000000005);
        tomoki
        @lasse-lindqvist
        Thank you for your reply.
        I also noticed the data being swapped.
        However, if I just replace the relevant part of the tekla IFC, it rotates 90 degrees. So I am wondering if something else is affecting it. I have also attached the IFC that I rewrote below.
        original
        modified
        #42= IFCRECTANGLEPROFILEDEF(.AREA.,‘\X2\0043004F004E25A1003600350030002A003300350030\X0’,#41,650.,350.);
        Girder_TEKLA_swapped_data.ifc
        • E esme referenced this topic on
