  4. Java4Shell vulnerability (CVE-2026-114938)
5 Posts 5 Posters 425 Views
    wrote last edited by tonigyllenberg
    Dear Society members,
    We are aware of the recently disclosed Java4Shell vulnerability (CVE-2026-114938) and are actively working to address it. Updates to our cloud-based services are being applied in the background. Once an updated Java version is available, we will also release an updated installer for the desktop application.
    Workaround:
    As a temporary precaution, customers using the desktop application may add the following option to their .vmoptions file:
    -XX:-UseBASE64Intrinsics
    This setting disables the affected Java Base64 optimization and helps reduce exposure while we complete and distribute the permanent fix.
    To apply this option:
    1. Close Solibri.
    2. Open the Solibri.vmoptions file in the installation folder, typically C:\Program Files\Solibri\SOLIBRI.
    3. Add -XX:-UseBASE64Intrinsics on a new line.
    4. Save the file and relaunch Solibri.
    We will share further updates as they become available.
    The Solibri team
    • Peter VlugP Online
      Peter VlugP Online
      Peter Vlug
      @tonigyllenberg
      Is this workaround also applicable to version 25.12 and earlier versions, including the Solibri “Anywhere” version that is installed alongside the newer 26 version(s)?
        replied to Peter Vlug last edited by
        @Peter-Vlug said in Java4Shell vulnerability (CVE-2026-114938):
        Check the Java version from logs or File->Help->System Information->Java Version
        If you have OpenJDK 17.0.6 or later -> apply the fix.
        The older Java versions don’t have the Java4Shell vulnerability.
          Mvandenbrink
          @Matti and @tonigyllenberg Any news on this vulnerability? Can we expect a Solibri desktop update anytime soon?
          • H Offline
            H Offline
            HieuVH-FPT
            I noticed that Adoptium has now released an updated JDK 21 build for Windows that addresses CVE-2026-114938.
            Since the announcement mentioned that an updated Solibri installer would be released once an updated Java version became available, could you please let me know if there is now a plan or estimated timeline for the updated installer?
