  3. Licensing issues
Licensing issues
52 Posts 8 Posters 9.7k Views
  • SigneLaksaaS Offline
    SigneLaksaa
    Problem today as well…
    • fmohusF Offline
      fmohusF Offline
      fmohus
      UPDATE: Still seems unstable, the next login failed here as well.
        You can try following workaround:
        Solibri installation has a certificate store file. I imported the Digicert certificate into that.
        1. Take a backup of this file “C:\Program Files\Solibri\SOLIBRI-26.4.1\jre\lib\security\cacerts”
        2. Replace the file with the one that is inside the attached zip
        3. Start Solibri
          cacerts.zip
          LeifHagen
          #38
          @Matti said in Licensing issues:
          3. Start Solibri
            cacerts.zip
          Tested now, still no license
            Hello all!
            As an update on the situation: Based on the current understanding, the issue seems to be related to Akamai datacenter. This explains why the situation is limited to Norway.
            For the time being, in order to regain access to Solibri, have your network or system administrator add a static A record on your corporate internal DNS server:
            Hostname: cacerts.digicert.com
            IP Address: 23.218.216.34
              LeifHagen
              Please inform us when there is a permanent fix for this issue as we wish to roll back the static IP when possible
                replied to LeifHagen on last edited by
                #41
                @LeifHagen said in Licensing issues:
                We will make sure to do so. We are awaiting more information from the data center on when the issue is resolved.
                  Patrick
                  wrote on last edited by Patrick
                  #42
                  Tried 25.12, so far no issues. FYI.
                  Never mind, still there.
                    replied to Patrick on last edited by
                    #43
                    @Patrick said in Licensing issues:
                    Yes, the issue with the data center is still ongoing. We are in contact with them however there is so far no updates.
                    • E Offline
                      E Offline
                      EdvinT
                      Hi! I work in IT support in Sweco, and wanted to share a “quick fix”
                      If you go to C:\Windows\System32\drivers\etc
                      You will see a file called hosts. If you open it and paste this line at the end of it:
                      23.218.216.34 cacerts.digicert.com
                      This will solve the problem on the affected computer.
                      This will require admin rights. If it doesn’t work for you, open the file and make sure that saving worked properly. You can’t just hit ctrl+S in a protected file.
                        Patrick
                        replied to EdvinT on last edited by
                        #45
                        @EdvinT Thank you, worked for me.
                        E 1 Reply Last reply
                        • E Offline
                          E Offline
                          EdvinT
                          #46
                          @Patrick glad to hear 🙂
                            Hello everyone,
                            We are pleased to inform you that this issue has been resolved in our upcoming release, version 26.6.0, coming out next tuesday.
                            The root cause of the disruption was traced to a third-party data center dependency. As we have not received a resolution or clear timeline from the provider, we have taken steps on our side to eliminate this dependency entirely.
                            With version 26.6.0, the required certificate is now included directly in the Solibri installation package, and we will remove the need for any external connection to a third-party certificate service, which will prevent similar issues going forward.
                            Once you upgrade to version 26.6.0, no additional configuration or workarounds will be needed. For those of you still working with 25.12.X or 26.4.X versions, we are working to provide a patch for those as well.
                            Thank you for your patience while we worked to resolve this.
                            • E Offline
                              E Offline
                              EdvinT
                              That is great. Tuesday 30th or 7th?
                                Tuesday 30th is the target
                                  Regimantas
                                  Hi have there been any news in regards of the Akamai datacenter?
                                    replied to Regimantas on last edited by
                                    #51
                                    @Regimantas said in Licensing issues:
                                    No news from their side unfortunately. The fix will be coming soon for Solibri users:
                                    @tonigyllenberg said in Licensing issues:
                                    Hello everyone,
                                      26.6.0, 25.12.1 and 26.4.1 are now available as a resolution for this issue.
                                      https://society.solibri.com/post/14812
