"Nearest Space" don't works correctly
Hi all,
I add a sample of a wall, showing an incorrect “Nearest Space”. It’s very strange…
I attach a ZIP that contains:
- 1 IFC of a wall
- 1 IFC with 6 spaces
- 1 SMC with the two IFCs
Xavier Coll
EiPM
@Xavier said in "Nearest Space" don't works correctly:
Thanks for the files! I will add them to Solibri database for further investigation.
@Xavier You are right, this is strange and confusing.
To sum it up:
- Nearest Space (Location) is giving the “wrong” space - but sometimes it could be also right.
- Nearest Space (Relation) is however working correctly.
As ITO and relations are a mighty tool but also always a bit tricky, I wanted to ask at this point if there is a good guide or tutorial available to finally fully understand the concept? -
J JSN referenced this topic on
