  4. "Nearest Space" don't works correctly
6 Posts 3 Posters 1.7k Views
  • XavierX Offline
    XavierX Offline
    Xavier
    Hi all,
    I add a sample of a wall, showing an incorrect “Nearest Space”. It’s very strange…
    I attach a ZIP that contains:
    • 1 IFC of a wall
    • 1 IFC with 6 spaces
    • 1 SMC with the two IFCs
    Xavier Coll
    EiPM
    Nearest_Space_problem.zip
    XavierX 1 Reply Last reply
    • XavierX Offline
      XavierX Offline
      Xavier
      replied to Xavier on last edited by Xavier
      It’s really strange… the same SMC file opened in different times: sometimes “Nearest Space” works well and sometimes not…
      I attached a screenshot and a video (in a zip file)
      Xavier Coll
      Nearest_Space_Problem.zip
      • XavierX Offline
        XavierX Offline
        Xavier
        This post is deleted!
          wrote on last edited by Matti
          @Xavier said in "Nearest Space" don't works correctly:
          Thanks for the files! I will add them to Solibri database for further investigation.
            @Xavier You are right, this is strange and confusing.
            To sum it up:
            • Nearest Space (Location) is giving the “wrong” space - but sometimes it could be also right.
            • Nearest Space (Relation) is however working correctly.
            As ITO and relations are a mighty tool but also always a bit tricky, I wanted to ask at this point if there is a good guide or tutorial available to finally fully understand the concept?
            • XavierX Offline
              XavierX Offline
              Xavier
              Thanks a lot for your fast answer, @matti-kannala
              Xavier Coll
