  3. Import Excel Worksheet - Rule#203
importexcelworksheetrule203
18 Posts 7 Posters 6.1k Views
    I have not really used it, but I think you would have to specify the Operator and the Numeric Value too then.
    EDIT: You are right - this is either not user friendly enough, or just not working as it should.
    Why is there not a good documentation of such things?
      Turns out we are not alone.
      https://society.solibri.com/topic/978/rule-203-numeric-value-without-unit?_=1610019703710
      So yeah, the question left is now what hast to be inserted for “Unit” when you want to leave it out - because otherwise it works. If the specification is correct then updating is possible as well.
      @Solibrians will you give us a hint?
      • paola bronzoP Offline
        paola bronzo
        @jsn said in Import Excel Worksheet - Rule#203:
        Yes, I should have specify the Operator and the Numeric value…but how?
        What is the correct writing to put in excel so that it is automatically read by the rule?
        You are right, we would need some more documentation.
          paola bronzo
          Thanks @JSN !!! this is interesting!
            paola bronzo
            @JSN I did some tests with an excel worksheet formatted as shown below … but I can’t get the desired result.
            @Solibrians is there a guide on how to write the excel file so that all the possible values are read by the rule?
            JSNJ chrisC 2 Replies Last reply
              Hi. Can you try using Area/Length/Volume/Date as the unit?
                paola bronzo
                @lasse-lindqvist yes, I tried to do it but nothing changes … also the “update imported data” still does not work …
                  replied to paola bronzo on last edited by JSN
                  @paola-bronzo said in Import Excel Worksheet - Rule#203:
                  @lasse-lindqvist Yes, that would be great.
                  @paola-bronzo
                  Did you make sure the headers are all matching - at least when using units like m or m2, the full line should load correctly and then you are able to update …
                    @lasse-lindqvist
                    With Units it’s working as shown above, but what is the secret symbol for no unit now?
                    Afaik it’s not “”, " ", “*”, “-”, “_”, …
                      paola bronzo
                      @jsn Thanks ;)! Now It works!
                        @paola-bronzo
                        Ok, let’s see if we also find out more about the lost symbol for no units.
                        In the meantime, a note about consistency and UX, as your table brought light into another very confusing thing.
                        @Solibrians Why is the import drop down menu header called “Unit” whilst in the UX dialog it’s clearly labeled with “Quantity”? This is confusing. Probably just a legacy thing, but still.
                          @lasse-lindqvist
                          Would be great to learn more about it as it still is a bit of a mystery and I have not yet found it out on my own …
                            This has been fixed in Solibri 9.12.7. Please try out the new version and let us know how it feels!
                              @Solibrians Is there a guide how to write the excel file?
                              MattiM john.lippJ 2 Replies Last reply
                                @chris
                                No guide. Try to use this as an example:
                                C:\Users\Public\Solibri\SOLIBRI\Samples\data\Required Property Sets.xlsx
                                • john.lippJ Offline
                                  john.lippJ Offline
                                  john.lipp
                                  @chris
                                  Here is a XLSX that has a picklist/cheatsheet that you can use to copy/paste cells from to your required property sets sheet along with providing hints:
                                  Required_Property_Sets_Picklist.xlsx
                                  Some things things to note:
                                  • You can use asterisks and question mark wild card characters in your pset, property, and property values.
                                  • There are many ways to specify units (even gallons for volumes), and it should convert to your File > Settings > Units that you have set.
                                  • To set the True, False, True or False value for a boolean property, it goes in the “String Value” column
                                  • You can use any color you want (the picklist has some standard ones), and the percent is how transparent. NOTE: XLS will limit the colors so its better to use XLSX. NOTE: You see the colors in the Rule Tools.
                                  • Use a semicolon to separate an enumeration.
                                  • For the equal numerical operator, use ‘eq’. You can NOT use equals sign (=), though you can use >= and <=
                                  Example : 5a8aaddc-d923-4a8f-a13d-b54bec3bc27e-image.png
                                  chrisC 1 Reply Last reply
                                  3
                                    #18
                                    @john-lipp Thank you very much 😊
                                    • john.lippJ john.lipp referenced this topic on
