  4. Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear
16 Posts 3 Posters 3.5k Views
    Noushed Solibrians
    Hi @Xavier,
    There is some issues regarding duplicate components in the viewpoint you were trying to post. That is why the viewpoint is not getting exported. Could you try to reproduce the same behaviour in our latest beta 9.12.2?
    As @JSN mentioned, with BIMcollab there is an existing issue that BIMcollab does not show viewpoint in there UI if it does not have any comment attached to it
    XavierX 1 Reply Last reply
    • XavierX Offline
      XavierX Offline
      Xavier
      replied to Noushed on last edited by Xavier
      Hi @noushed and @JSN ,
      First of all, thanks for yours answers,
      This issue happens with Solibri 9.12.1.9, with BIMsync and BIMcollab. The process did it in BCF Live connection is:
      • Test always creating a new SMC file
      • I created a new isse in Solbri tool “BCFLive” Connection
      • I test the same process connecting BIMsync, and BIMcollab (Free and also a Professional accoount).
      Later I will try with Solibri Beta version.
      Xavier Coll
      EiPM
      • XavierX Offline
        XavierX Offline
        Xavier
        replied to Xavier on last edited by
        Good afternoon @Noushed and @JSN ,
        I tested the Solibri Beta 9.12.2, and about the issue of dissapeared images of an issue created in Solibri-BCFlive:
        • Test in BIMcollab -> it seems to work
        • Test in BIMsync -> it seems to work
        Special note:
        In the first test, I started synchronizing with BIMsync, and Solibri did something strange:
        • In Solibri-BCFLive, I created a new issue
        • After 1st syncronization, in BCFLive list, a copy of the issue, appeared in the list of issues.
        • After 2nd syncronization, in BCFLive list, a 2nd copy of the issue, appeared in the list of issues.
        • After 3nd syncronization, in BCFLive list, a 3nd copy of the issue, appeared in the list of issues.
        • I decided to close Solibri.
        I re-started Solibri again, but this “repeat” issue was not replicated (by now…)
        Xavier Coll
        N 1 Reply Last reply
          Noushed Solibrians
          Hi @xavier,
          Have you checked if the viewpoint truly get exported to BCF server? I meant in BIMcollab/bimsync server UI, can you see the viewpoint after solibri sync is done?
          • XavierX Offline
            XavierX Offline
            Xavier
            Hi @noushed,
            Yes! I attach a video.
            Xavier Coll
            EiPM
            video.zip
            JSNJ N 2 Replies Last reply
              replied to Xavier on last edited by JSN
              @xavier said in Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear:
              That’s also good to know.
              When you do not add a comment …
              … it wont be visible in the history (as discussed above) …
              … but you can select it here manually?
              So it indeed get’s synced, but BIMcollab does not want to / or cannot show it in the history itself? For me this makes no sense.
                Noushed Solibrians
                Hi @Xavier,
                Thanks for the confirmation. If possible please also try to export the same viewpoint (same model with the Colored components in it) what you were trying to export initially and the reported bug was visible.
                  Noushed Solibrians
                  Hi @jsn,
                  Have you reported it to BIMcollab regarding the viewpoint without comment to show it in issue history?
                    @noushed said in Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear:
                    Yes.
                    • XavierX Offline
                      XavierX Offline
                      Xavier
                      Thanks @jsn for the clarification. Very interesting!
                      Hi @Noushed,
                      I test to create new issues, without to add description (no comments), and also they works.
                      I attach a video.
                      Xavier Coll
                      EiPM
                      210107_Test_02.zip
