  4. Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear
16 Posts 3 Posters 3.2k Views
  • XavierX Offline
    XavierX Offline
    Xavier
    Hi all,
    I’m testing the new tool “BCF Live Connector”, connecting with BIMsync, and it’s impressive.
    But I have some problems when I create new issues in Solibri: Screenshots dissapear… And this happens with BIMsync and also BIMcollab Live connection…
    I attach a video explain it.
    Any solution?
    Xavier Coll
    EiPM
    210105_BCF-LC_Issue.zip
      Noushed Solibrians
      Hi @Xavier,
      Could you share us/support ([email protected]) the log files? You can find those in “C:\Program Files\Solibri\SOLIBRI\log”
      • XavierX Offline
        XavierX Offline
        Xavier
        Hi @Noushed ,
        Just right now I sended the requested log folder (in a zip file) to the requested email.
        Thanks and best regards,
        Xavier Coll
          @xavier said in Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear:
          Speaking for BIMcollab, I made the experience that when adding a new image to an issue in Solibri, it is necessary to always add a comment or the snapshots will be lost. Try it out. (Btw, this is actually a thing they should write somewhere in big bold letters …)
          This is actually the case when you want to add further screenshots to existing issues - BimCollab says it works as it should. I doubt it. However, I think it should not happen when you create a new issue - will try that out later.
          XavierX 1 Reply Last reply
          • XavierX Offline
            XavierX Offline
            Xavier
            Good mornig @jsn ,
            Thanks for your test. I tried everything, and I tried by adding title, description, status, all. But the problem still here. It’s very strange.
            Xavier Coll
            EiPM
              BIMsync and BIMcollab? Are you on the latest version of 9.12.1.9?
              For BIMcollab I can at least verify that your first problem - disappering screenshots during a new issue creation in BCF Live - are definitely not happening here, there is something not working correctly for you.
              For the second described problem - the loss of screesnhots from existing issues - this might me “normal”, but if you are facing other problems then there might be a relationship too.
              Anyhow, I guess this information won’t help you much either, but I am curious what might cause your problems.
                Noushed Solibrians
                Hi @Xavier,
                There is some issues regarding duplicate components in the viewpoint you were trying to post. That is why the viewpoint is not getting exported. Could you try to reproduce the same behaviour in our latest beta 9.12.2?
                As @JSN mentioned, with BIMcollab there is an existing issue that BIMcollab does not show viewpoint in there UI if it does not have any comment attached to it
                • XavierX Offline
                  XavierX Offline
                  Xavier
                  replied to Noushed on last edited by Xavier
                  Hi @noushed and @JSN ,
                  First of all, thanks for yours answers,
                  This issue happens with Solibri 9.12.1.9, with BIMsync and BIMcollab. The process did it in BCF Live connection is:
                  • Test always creating a new SMC file
                  • I created a new isse in Solbri tool “BCFLive” Connection
                  • I test the same process connecting BIMsync, and BIMcollab (Free and also a Professional accoount).
                  Later I will try with Solibri Beta version.
                  Xavier Coll
                  EiPM
                  • XavierX Offline
                    XavierX Offline
                    Xavier
                    replied to Xavier on last edited by
                    Good afternoon @Noushed and @JSN ,
                    I tested the Solibri Beta 9.12.2, and about the issue of dissapeared images of an issue created in Solibri-BCFlive:
                    • Test in BIMcollab -> it seems to work
                    • Test in BIMsync -> it seems to work
                    Special note:
                    In the first test, I started synchronizing with BIMsync, and Solibri did something strange:
                    • In Solibri-BCFLive, I created a new issue
                    • After 1st syncronization, in BCFLive list, a copy of the issue, appeared in the list of issues.
                    • After 2nd syncronization, in BCFLive list, a 2nd copy of the issue, appeared in the list of issues.
                    • After 3nd syncronization, in BCFLive list, a 3nd copy of the issue, appeared in the list of issues.
                    • I decided to close Solibri.
                    I re-started Solibri again, but this “repeat” issue was not replicated (by now…)
                    Xavier Coll
                    N 1 Reply Last reply
                      Noushed Solibrians
                      Hi @xavier,
                      Have you checked if the viewpoint truly get exported to BCF server? I meant in BIMcollab/bimsync server UI, can you see the viewpoint after solibri sync is done?
                      • XavierX Offline
                        XavierX Offline
                        Xavier
                        Hi @noushed,
                        Yes! I attach a video.
                        Xavier Coll
                        EiPM
                        video.zip
                        JSNJ N 2 Replies Last reply
                          replied to Xavier on last edited by JSN
                          That’s also good to know.
                          When you do not add a comment …
                          … it wont be visible in the history (as discussed above) …
                          … but you can select it here manually?
                          So it indeed get’s synced, but BIMcollab does not want to / or cannot show it in the history itself? For me this makes no sense.
                            Noushed Solibrians
                            Hi @Xavier,
                            Thanks for the confirmation. If possible please also try to export the same viewpoint (same model with the Colored components in it) what you were trying to export initially and the reported bug was visible.
                              Noushed Solibrians
                              Hi @jsn,
                              Have you reported it to BIMcollab regarding the viewpoint without comment to show it in issue history?
                                @noushed said in Solibri 9.12.1: In BCF Live Connector, the screenshots of the new Issues disappear:
                                Yes.
                                • XavierX Offline
                                  XavierX Offline
                                  Xavier
                                  Thanks @jsn for the clarification. Very interesting!
                                  Hi @Noushed,
                                  I test to create new issues, without to add description (no comments), and also they works.
                                  I attach a video.
                                  Xavier Coll
                                  EiPM
                                  210107_Test_02.zip
