  3. Functions in ITO reports
16 Posts 7 Posters 4.5k Views
    replied to Bram 0 on last edited by JSN
    @Bram-0 said in Functions in ITO reports:
    On the other hand there is also no information on the web specifically for Java on Solibri, at least not free, that I have found. If you know if there is information to be able to learn to program specifically for the Solibri extension, I would be grateful. Greetings.
    You are right the getting started guides could be better, but there are some ressources which can be found here. Anyhow in this specific case I was not refering to the Java API but I menat the JavaScript support for the ITOs which has quite a good quickstart tutorial - check if you have access.
    https://society.solibri.com/topic/620/javascript-api-documentation-solibri-version-9-10-8
    I only know a little about Excel and XML, nothing about Java or other languages, so in the short term it would not be applicable, at least in my case.
    I gues you could also try to use Power Query with the template as a crutch for now to at least automate the splitting.
    B E 2 Replies Last reply
    • bariscanpolatB Offline
      bariscanpolat
      Hi @JSN
      The link generates the following error:
      “Access Denied
      You seem to have stumbled upon a page that you do not have access to.”
        replied to bariscanpolat on last edited by
        @bariscanpolat
        @Solibrians need to give you access privileges
        B W 2 Replies Last reply
          Bram 0
          @JSN I would also like to be able to access the link
            Bram 0
            @JSN said in Functions in ITO reports:
            The problem is that the office works with google sheets, and in this case the Querry function is used. What I would like is to do it from the same file or template
            • W Offline
              W Offline
              Wing Mang
              @JSN
              I’d also like to get access to the link too.
              It’s something new to me.
                @Bram-0
                The split can be done in the Excel template of Solibri ITO.
                Use following functions in additional columns
                =LEFT(B12;FIND(" : ";B12))
                =RIGHT(B12; LEN(B12) - FIND(" : ";B12) - 2)
                and the result:
                  Bram 0
                  Hello @Matti-Kannala , very grateful for your answer, I see that it helps me so that everything comes out from the template, but the only details are that if there are blank cells, the value “#VALUE!” remains, on the other hand, it does not recognize the “IFERROR” formula. since all the boxes remain in value “=0”. I’m going to try the “IF” formula to see if I get something. Greetings
                    We had issues in the past that some formulas or formatings of the report templates are not properly supported. So in some cases there is just nothing happening on a report export. It’s not doing anything until you delete such columns. No errors, no hints, no logs (?), just nothing.
                    B 1 Reply Last reply
                      Bram 0
                      @JSN Sometimes that happens to me when I save in google sheets, I don’t know why, but when I export it from Numbers (mac) it accepts the template and exports from Solibri without problems…
                        @Bram-0
                        Just using excel and sometimes it feels like a bit hit and miss if it’s working or not. Regarding IFERROR() on the other hand I am pretty sure it works so maybe check your formula again.
                        • E Offline
                          E Offline
                          EloyRD
                          @Solibrians Could you point me towards the current tutorial? Sorry for commenting on a quite old post.
                            replied to EloyRD on last edited by
                            For JavaScript API the latest documentation is here:
                            https://society.solibri.com/topic/3368/solibri-api-solibri-javascript-api
