  4. How do I update Rules in RuleSets
17 Posts 8 Posters 6.1k Views
    I have a general RuleSet for the whole office no matter the project type. When a project starts, adjustemnts of that RuleSet will be made to fit the project requirements and saved as an extra project specific RuleSet.
    Question:
    If I update in the future a ceratin Rule in my general RuleSet, how do I bring that updated rule into my project specific RuleSet (after this RuleSet has done some checking in the project)? Drag and Drop in the RuleSet Manager just creates a new rule and does not overwrite it. Or is manual adjustment, the only solution to update that Rule in the project specific project?
    TriPoint GmbH
    www.tri-point.at
    D 1 Reply Last reply
    • D Offline
      D Offline
      dothedew
      @agroni
      Save your new Ruleset in the folder C:\Users\Public\Solibri\SOLIBRI\Rulesets. Then tell Solibri to open that Ruleset. Or combine all your Rules into one Ruleset and only enable the Rules (right click the rule in the Checking tab) that a particular projects needs and disable the ones it doesn’t.
      agroniA 1 Reply Last reply
        replied to dothedew on last edited by
        @dothedew
        But that imports the complete RuleSet resulting in the same RuleSet twice in that project. In addition, enabling just the newest RuleSet, will not control if previous issues (from the old RuleSet) have been solved.
        I was talking more of updating one Rule between two RuleSets. Here the explanation:
        My gerenal RuleSet called ABC hast 10 Rules, from which one of them is called “Doors”. The project specific RuleSet is called ABC_PR and has the same amount of rules and especially the “Doors”. In the meantime I update the “Doors” Rule in ABC and I want just the “Doors” in a simple way to bring it to ABC_PR.
        TriPoint GmbH
        www.tri-point.at
          Well, you can indeed work with User Roles which ensures that your latest Rulesets/ITOs/Classifications are loaded from your Master Developement Root Path on the Server everytime any of your clients start Solibri - this gives you the possibility of keeping your “Office Standard” up-to-date.
          However, it seems that this is only applying for NEW SMC files - the resources are inherited right when you create the Solibri file.
          Once the SMC is saved, this “bidirectional link” to the root path is “broken”, meaning all the rules (…) and its changes are now stored in your Solibri Project and no changes to the Master-Ruleset on the server will be loaded into exisiting projects. (BUT BE CAREFUL: Overwritting the Master could indeed happen if the permission settings do not prevent it!)
          This concept actually makes sense because if your Master always updates (and overwrittes) your rules you would not have the possibility to “customize” your template for each new Project … so I am afraid when you update specific rules the only way to “update” this rule instances in the different projects is to either adjust or replace them manually - but the last one does not keep all the legacy stuff.
          Nevertheless, I think when we are speaking of such a centralized ruleset administration, there is definitely some room for improvements. It is actually pretty anoying when have lots of different projects with different versions of the office standard - especially when you implement new rules, you tend to update and fix them more frequently.
            Anne
            @Agroni,
            So far we know the way you like it works, isn’t possible at the moment in Solibri. Maybe Solibri can tell or they have plans to implement.
            • _c__ Offline
              _c__ Offline
              _c_
              I’d like to refresh this thread.
              Is there a trick to re-load a rule from the resource path or do we REALLY need to edit every file wherever the obsolete once have issues?
              c
                @_c_ said in How do I update Rules in RuleSets:
                I am afraid that you have to reload the ruleset manually in each file where you want to “update”.
                • _c__ Offline
                  _c__ Offline
                  _c_
                  But we are loosing the links to the issues when doing that. How do you do it, so that it doesn’t happen?
                  c
                    Hi. Check also an upcoming version where rulesets can be externalized to a common location (https://society.solibri.com/topic/1194/upcoming-solibri-version-testers-wanted/17).
                    If there you update the ruleset, say, on a network drive or a OneDrive folder, all projects that refer to it, automatically always load the newest version.
                    T _c__ 2 Replies Last reply
                      TheoR
                      #10
                      @lasse-lindqvist will this also apply to Classifications and Information Takeoffs?
                      L 1 Reply Last reply
                        replied to TheoR on last edited by lasse.lindqvist
                        #11
                        @theor said in How do I update Rules in RuleSets:
                        Yes, both are externalizable in the same way. Externalizing them is of course optional and the old way of handling them can still be used if wished.
                        • _c__ Offline
                          _c__ Offline
                          _c_
                          #12
                          @lasse-lindqvist thank you.
                          We are going nuts with paths in Solibri. May I also hope that we’ll have relative paths now?
                          c
                            replied to _c_ on last edited by
                            #13
                            @_c_
                            In which use case scenarios? What I am most afraid of is the fear of breaking rules, ITOs, … because classification names have been modified. Will this finally going to be fixed?
                            • _c__ Offline
                              _c__ Offline
                              _c_
                              I did an extensive list of observations a while ago, here. I made exact lists towards the end of the thread.
                              Some I saw as solved. I discovered, later, that on Mac the Application is always overridden, this is certainly a bug.
                              Then that there is an ini file where paths are stored, that helps.
                              Etc.
                              c
                              • I Offline
                                I Offline
                                ILikeAnArch
                                I have one question regards rulesets.
                                The scenario:
                                1. I use ruleset manager to create the XXX Ruleset and save to C Drive
                                2. I add to the project Checking
                                3. I run the XXX Ruleset
                                4. I now want to add some additional Rules from the Library to the original XXX Ruleset
                                5. I now override the XXX Ruleset on the C Drive through Ruleset Manager
                                6. I can load the revised XXX Ruleset into the project….
                                But, the additional rules don’t come over. I am still with the original rules only.
                                As mentioned above, the only solution I can find is to delete and load the ruleset again, loosing the previous issues.
                                Am I missing something?
                                  I’m reviving this old post of mine from five years ago, because I’m facing a similar situation on a current project.
                                  I have three different SMC files that each include two rulesets (csets). One of them is the QualityGate Check, which should be identical across all three files. I’ve noticed that when I modify this ruleset and save it, the changes do not propagate to the other SMC files. The ruleset is also assigned via role. The only workaround that currently works for me is to delete the ruleset in each file and re-import it, but that causes me to lose all existing checking results.
                                  Has there been any progress on this in the last five years? Is there an efficient way to synchronize rulesets across multiple files without losing results?
                                  TriPoint GmbH
                                  www.tri-point.at
                                  • _c__ Offline
                                    _c__ Offline
                                    _c_
                                    Yes please, resolve this problem.
                                    c
