  3. Licensing issues
Licensing issues
52 Posts 8 Posters 6.1k Views
    replied to LeifHagen on last edited by
    #41
    @LeifHagen said in Licensing issues:
    Please inform us when there is a permanent fix for this issue as we wish to roll back the static IP when possible
    We will make sure to do so. We are awaiting more information from the data center on when the issue is resolved.
    Toni
      Patrick
      wrote on last edited by Patrick
      #42
      Tried 25.12, so far no issues. FYI.
      Never mind, still there.
        replied to Patrick on last edited by
        #43
        @Patrick said in Licensing issues:
        Yes, the issue with the data center is still ongoing. We are in contact with them however there is so far no updates.
        • E Offline
          E Offline
          EdvinT
          Hi! I work in IT support in Sweco, and wanted to share a “quick fix”
          If you go to C:\Windows\System32\drivers\etc
          You will see a file called hosts. If you open it and paste this line at the end of it:
          23.218.216.34 cacerts.digicert.com
          This will solve the problem on the affected computer.
          This will require admin rights. If it doesn’t work for you, open the file and make sure that saving worked properly. You can’t just hit ctrl+S in a protected file.
          P 1 Reply Last reply
            Patrick
            replied to EdvinT on last edited by
            #45
            @EdvinT Thank you, worked for me.
            E 1 Reply Last reply
            • E Offline
              E Offline
              EdvinT
              #46
              @Patrick glad to hear 🙂
                Hello everyone,
                We are pleased to inform you that this issue has been resolved in our upcoming release, version 26.6.0, coming out next tuesday.
                The root cause of the disruption was traced to a third-party data center dependency. As we have not received a resolution or clear timeline from the provider, we have taken steps on our side to eliminate this dependency entirely.
                With version 26.6.0, the required certificate is now included directly in the Solibri installation package, and we will remove the need for any external connection to a third-party certificate service, which will prevent similar issues going forward.
                Once you upgrade to version 26.6.0, no additional configuration or workarounds will be needed. For those of you still working with 25.12.X or 26.4.X versions, we are working to provide a patch for those as well.
                Thank you for your patience while we worked to resolve this.
                • E Offline
                  E Offline
                  EdvinT
                  That is great. Tuesday 30th or 7th?
                    Tuesday 30th is the target
                    • R Offline
                      R Offline
                      Regimantas
                      Hi have there been any news in regards of the Akamai datacenter?
                        replied to Regimantas on last edited by
                        #51
                        @Regimantas said in Licensing issues:
                        No news from their side unfortunately. The fix will be coming soon for Solibri users:
                        @tonigyllenberg said in Licensing issues:
                        Hello everyone,
                          26.6.0, 25.12.1 and 26.4.1 are now available as a resolution for this issue.
                          https://society.solibri.com/post/14812
