Startup Issue : java.security.cert.X509 error
I’m suddenly getting this error when I try to run Solibri Office - tried uninstalling and reinstalling the latest version but no dice… anyone got any ideas how to fix this? It still runs okay on other PCs in the office…
@celineman @keithwilkinson Glad to hear all is fine now!
We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
Despite this, we apologise for the inconvenience. -
Weirdly, I’m glad it’s not just me…
Yes, the problem is still there. But not on all PCs.
Our support got similar error reports mostly from UK.
Are you using Mac or Windows?
Locating in UK? -
In case of Windows, try adding this option to “C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions”
-Djavax.net.ssl.trustStoreType=WINDOWS-ROOT -
@celineman did you try that option?
@Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
Just to check if you are having some firewall or similar that could affect:
- Open https://api.solibri.com/ to you browser (Chrome)
- Click the icon in front of the address bar
- Click “Connection is Secure”
- Click “Certifcate is valid” (In Edge browser there is a Certificate icon instead)
- Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
That all seems to match here.
This is what I got
In that page:
- Click the Details:
- Click Export… and save the cert to local disk
- Click Windows key
- Type “CMD”
- Right Click the Command Prompt icon appearing
- Click “Run as Administrator”
- Run command
“C:\Program Files\Solibri\SOLIBRI\jre\bin\keytool.exe” -import -noprompt -cacerts -alias api.solibri.com -file “<path to the file exported file>” - Type “changeit”
any other ideas on this?
