34 Posts 11 Posters 13.0k Views
    keithwilkinson
    @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
    Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
      wrote on last edited by Matti
      Just to check if you are having some firewall or similar that could affect:
      5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
      K 1 Reply Last reply
        celineman
        This is what I got @Matti-Kannala
          keithwilkinson
          That all seems to match here.
              keithwilkinson
                This is what I got
                In that page:
                1. Click the Details:
                3. Click Windows key
                4. Type “CMD”
                7. Run command
                8. Type “changeit”
                  celineman
                    keithwilkinson
                      keithwilkinson
                      any other ideas on this?
                        Thanks in advance!
                          celineman
                          I can launch Solibri Office now
                            keithwilkinson
                            Same here - mysteriously working again. Any indication as to the cause?
                              wrote on last edited by Eric
                              @celineman @keithwilkinson Glad to hear all is fine now!
                              We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                              Despite this, we apologise for the inconvenience.
                                keithwilkinson
                                no worries, that would make sense. Thanks for the update.
                                • EricE Eric marked this topic as a question on
                                • EricE Eric has marked this topic as solved on
                                  celineman
                                  #26
                                  Hi, I have this startup problem again today. @Matti-Kannala
                                    Thanks for reporting. We are looking on this. I have not seen other reports yet.
                                      Mark-Felix
                                      Hi, I have this startup problem as well. @Matti-Kannala
                                      Firewall ports and Proxy settings are in accordance to Firewall-Settings. I recognized that Settings / General / User is empty. Any suggestion?
                                      • V Offline
                                        V Offline
                                        VarunS
                                        Is anyone still getting this issue? I seem to have this issue today, in the morning it worked fine, I came back after lunch to this message? No clue how to fix it.
                                        • V Offline
                                          V Offline
                                          vitoria.santos
                                          I’m having the same problem, i’m using it from Brazil
