34 Posts 11 Posters 14.6k Views
    keithwilkinson
    That all seems to match here.
      K 1 Reply Last reply
        keithwilkinson
          This is what I got
          In that page:
          1. Click the Details:
          3. Click Windows key
          4. Type “CMD”
          7. Run command
          8. Type “changeit”
            celineman
              keithwilkinson
                keithwilkinson
                any other ideas on this?
                  Thanks in advance!
                    celineman
                    I can launch Solibri Office now
                      keithwilkinson
                      Same here - mysteriously working again. Any indication as to the cause?
                        wrote on last edited by Eric
                        @celineman @keithwilkinson Glad to hear all is fine now!
                        We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                        Despite this, we apologise for the inconvenience.
                          keithwilkinson
                          no worries, that would make sense. Thanks for the update.
                          • EricE Eric marked this topic as a question on
                          • EricE Eric has marked this topic as solved on
                            celineman
                            #26
                            Hi, I have this startup problem again today. @Matti-Kannala
                              Thanks for reporting. We are looking on this. I have not seen other reports yet.
                                Mark-Felix
                                Hi, I have this startup problem as well. @Matti-Kannala
                                Firewall ports and Proxy settings are in accordance to Firewall-Settings. I recognized that Settings / General / User is empty. Any suggestion?
                                • V Offline
                                  V Offline
                                  VarunS
                                  Is anyone still getting this issue? I seem to have this issue today, in the morning it worked fine, I came back after lunch to this message? No clue how to fix it.
                                  • V Offline
                                    V Offline
                                    vitoria.santos
                                    I’m having the same problem, i’m using it from Brazil
                                    • HartwigH Offline
                                      HartwigH Offline
                                      Hartwig
                                      https://society.solibri.com/topic/3183/downtime-event-in-progress
                                        Ryan.Howe
                                        wrote on last edited by Ryan.Howe
                                        #32
                                        Getting the same error message when trying to launch autorun. Based in UK.
                                          JohnFord
                                          @Matti I am getting this error this morning. First time I have seen it?
