34 Posts 11 Posters 14.6k Views
    keithwilkinson
    Weirdly, I’m glad it’s not just me…
      celineman
      Are you still having this error this morning? I still have it…
        keithwilkinson
        Yes, the problem is still there. But not on all PCs.
          Our support got similar error reports mostly from UK.
          Are you using Mac or Windows?
          Locating in UK?
            celineman
            I’m using Windows and I’m in the UK
              In case of Windows, try adding this option to “C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions”
              K 1 Reply Last reply
                @celineman did you try that option?
                  celineman
                  Is it just simply adding that line to Solibri.vmoptions? and then run Solibri?
                  I did that but doesn’t work… @Matti-Kannala
                    keithwilkinson
                    @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
                    Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
                      wrote on last edited by Matti
                      Just to check if you are having some firewall or similar that could affect:
                      5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
                        celineman
                        This is what I got @Matti-Kannala
                          keithwilkinson
                          That all seems to match here.
                              keithwilkinson
                                This is what I got
                                In that page:
                                1. Click the Details:
                                3. Click Windows key
                                4. Type “CMD”
                                7. Run command
                                8. Type “changeit”
                                  celineman
                                    keithwilkinson
                                      keithwilkinson
                                      any other ideas on this?
                                        Thanks in advance!
                                          celineman
                                          I can launch Solibri Office now
