34 Posts 11 Posters 14.6k Views
    keithwilkinson
    Yes, the problem is still there. But not on all PCs.
      Our support got similar error reports mostly from UK.
      Are you using Mac or Windows?
      Locating in UK?
        celineman
        I’m using Windows and I’m in the UK
          In case of Windows, try adding this option to “C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions”
          K 1 Reply Last reply
            @celineman did you try that option?
              celineman
              Is it just simply adding that line to Solibri.vmoptions? and then run Solibri?
              I did that but doesn’t work… @Matti-Kannala
                keithwilkinson
                @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
                Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
                  wrote on last edited by Matti
                  Just to check if you are having some firewall or similar that could affect:
                  5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
                    celineman
                    This is what I got @Matti-Kannala
                      keithwilkinson
                      That all seems to match here.
                          keithwilkinson
                            This is what I got
                            In that page:
                            1. Click the Details:
                            3. Click Windows key
                            4. Type “CMD”
                            7. Run command
                            8. Type “changeit”
                              celineman
                                keithwilkinson
                                  keithwilkinson
                                  any other ideas on this?
                                    Thanks in advance!
                                      celineman
                                      I can launch Solibri Office now
                                        keithwilkinson
                                        Same here - mysteriously working again. Any indication as to the cause?
                                          wrote on last edited by Eric
                                          @celineman @keithwilkinson Glad to hear all is fine now!
                                          We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                                          Despite this, we apologise for the inconvenience.
