34 Posts 11 Posters 14.6k Views
    celineman
    Is it just simply adding that line to Solibri.vmoptions? and then run Solibri?
    I did that but doesn’t work… @Matti-Kannala
      keithwilkinson
      @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
      Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
        wrote on last edited by Matti
        Just to check if you are having some firewall or similar that could affect:
        5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
        K 1 Reply Last reply
          celineman
          This is what I got @Matti-Kannala
            keithwilkinson
            That all seems to match here.
                keithwilkinson
                  This is what I got
                  In that page:
                  1. Click the Details:
                  3. Click Windows key
                  4. Type “CMD”
                  7. Run command
                  8. Type “changeit”
                    celineman
                      keithwilkinson
                        keithwilkinson
                        any other ideas on this?
                          Thanks in advance!
                            celineman
                            I can launch Solibri Office now
                              keithwilkinson
                              Same here - mysteriously working again. Any indication as to the cause?
                                wrote on last edited by Eric
                                @celineman @keithwilkinson Glad to hear all is fine now!
                                We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                                Despite this, we apologise for the inconvenience.
                                  keithwilkinson
                                  no worries, that would make sense. Thanks for the update.
                                  • EricE Eric marked this topic as a question on
                                  • EricE Eric has marked this topic as solved on
                                    celineman
                                    #26
                                    Hi, I have this startup problem again today. @Matti-Kannala
                                      Thanks for reporting. We are looking on this. I have not seen other reports yet.
                                        Mark-Felix
                                        Hi, I have this startup problem as well. @Matti-Kannala
                                        Firewall ports and Proxy settings are in accordance to Firewall-Settings. I recognized that Settings / General / User is empty. Any suggestion?
                                        • V Offline
                                          V Offline
                                          VarunS
                                          Is anyone still getting this issue? I seem to have this issue today, in the morning it worked fine, I came back after lunch to this message? No clue how to fix it.
