34 Posts 11 Posters 14.6k Views
    celineman
    This is what I got @Matti-Kannala
      keithwilkinson
      That all seems to match here.
        K 1 Reply Last reply
          keithwilkinson
            This is what I got
            In that page:
            1. Click the Details:
            3. Click Windows key
            4. Type “CMD”
            7. Run command
            8. Type “changeit”
              celineman
                keithwilkinson
                  keithwilkinson
                  any other ideas on this?
                    Thanks in advance!
                      celineman
                      I can launch Solibri Office now
                        keithwilkinson
                        Same here - mysteriously working again. Any indication as to the cause?
                          wrote on last edited by Eric
                          @celineman @keithwilkinson Glad to hear all is fine now!
                          We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                          Despite this, we apologise for the inconvenience.
                            keithwilkinson
                            no worries, that would make sense. Thanks for the update.
                            • EricE Eric marked this topic as a question on
                            • EricE Eric has marked this topic as solved on
                              celineman
                              #26
                              Hi, I have this startup problem again today. @Matti-Kannala
                                Thanks for reporting. We are looking on this. I have not seen other reports yet.
                                  Mark-Felix
                                  Hi, I have this startup problem as well. @Matti-Kannala
                                  Firewall ports and Proxy settings are in accordance to Firewall-Settings. I recognized that Settings / General / User is empty. Any suggestion?
                                  • V Offline
                                    V Offline
                                    VarunS
                                    Is anyone still getting this issue? I seem to have this issue today, in the morning it worked fine, I came back after lunch to this message? No clue how to fix it.
                                    • V Offline
                                      V Offline
                                      vitoria.santos
                                      I’m having the same problem, i’m using it from Brazil
                                      • HartwigH Offline
                                        HartwigH Offline
                                        Hartwig
                                        https://society.solibri.com/topic/3183/downtime-event-in-progress
                                          Ryan.Howe
                                          wrote on last edited by Ryan.Howe
                                          #32
                                          Getting the same error message when trying to launch autorun. Based in UK.
