34 Posts 11 Posters 14.6k Views
    Our support got similar error reports mostly from UK.
    Are you using Mac or Windows?
    Locating in UK?
      celineman
      I’m using Windows and I’m in the UK
        In case of Windows, try adding this option to “C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions”
        K 1 Reply Last reply
          @celineman did you try that option?
            celineman
            Is it just simply adding that line to Solibri.vmoptions? and then run Solibri?
            I did that but doesn’t work… @Matti-Kannala
              keithwilkinson
              @Matti-Kannala said in Startup Isse : java.security.cert.X509 error:
              Hi, tried adding that here but no joy. I’m also UK-based and using Windows.
                wrote on last edited by Matti
                Just to check if you are having some firewall or similar that could affect:
                5. Check that certifcate matches: Cloudflare, Inc. and public key 80d1db0dd47ad24ac24c05fe19273a1a4b39977563a3f9a69ae970b53a1b44fa
                  celineman
                  This is what I got @Matti-Kannala
                    keithwilkinson
                    That all seems to match here.
                        keithwilkinson
                          This is what I got
                          In that page:
                          1. Click the Details:
                          3. Click Windows key
                          4. Type “CMD”
                          7. Run command
                          8. Type “changeit”
                            celineman
                              keithwilkinson
                                keithwilkinson
                                any other ideas on this?
                                  Thanks in advance!
                                    celineman
                                    I can launch Solibri Office now
                                      keithwilkinson
                                      Same here - mysteriously working again. Any indication as to the cause?
                                        wrote on last edited by Eric
                                        @celineman @keithwilkinson Glad to hear all is fine now!
                                        We’re still investigating and so far the issue seems to point towards Cloudflare since this issue disappeared after they did a maintenance break earlier today, only for the UK.
                                        Despite this, we apologise for the inconvenience.
                                          keithwilkinson
                                          no worries, that would make sense. Thanks for the update.
                                          • EricE Eric marked this topic as a question on
                                          • EricE Eric has marked this topic as solved on
